Home: Gantry/Router Machines & Building
General discussion for the various moving gantry or router style cnc machines.
Page 3 of 38 FirstFirst 1234513 ... LastLast
Threads 41 to 60 of 746
Sub-Forums Threads / Posts  Last Post
  1. Here you can find the build logs of gantry type diy cnc machines built by our members.
    Forum Actions:
    Forum Statistics:
    • Threads: 330
  2. General discussion for the OpenBuilds OX cnc router machine.
    Forum Actions:
    Forum Statistics:
    • Threads: 12
  3. General discussion for commercial Boxford Routers.
    Forum Actions:
    Forum Statistics:
    • Threads: 8
  4. General discussion for the Denford range.
    Forum Actions:
    Forum Statistics:
    • Threads: 11
  5. General discussion for the commercial chinese routers, the 3040, 6040 and other variants.
    Forum Actions:
    Forum Statistics:
    • Threads: 147
  6. General discussion for the SCM Group wood routers.
    Forum Actions:
    Forum Statistics:
    • Threads: 5
  7. General discussion for the AXYZ International range of machines.
    Forum Actions:
    Forum Statistics:
    • Threads: 14
  8. General discussion for the range of machines available from Marchant Dice Ltd.
    Forum Actions:
    Forum Statistics:
    • Threads: 5
  9. General discussion for the Heiz routers.
    Forum Actions:
    Forum Statistics:
    • Threads: 20
  10. General discussion for the Rye range of cnc machines.
    Forum Actions:
    Forum Statistics:
    • Threads: 6
  1. Sticky Thread Sticky: Some thoughts on cnc machine design principles. . .
    Started by routercnc, 03-07-2010
    2 Pages
    1 2
    09-10-2020 Go to last post
  2. Sticky Thread Sticky: Beginner Moving Gantry Build? Read This!
    Started by Tenson, 21-09-2015
    23-05-2018 Go to last post
    25-06-2016 Go to last post
  3. Sticky Thread Sticky: Calculating timing belt lengths
    Started by Jonathan, 07-03-2013
    2 Pages
    1 2
    10-12-2015 Go to last post
  4. Sticky Thread Sticky: Why not use unsupported rails?
    Started by Jonathan, 31-03-2012
    4 Pages
    1 2 3 ... 4
    06-04-2012 Go to last post
  5. Sticky Thread Sticky: Unsupported Precision Round Rail Calculator
    Started by Ross77, 30-06-2010
    4 Pages
    1 2 3 ... 4
    24-08-2010 Go to last post
  1. y axis motor mounting suggestions
    Started by reefy86, 19-09-2021
    2 Pages
    1 2
    21-09-2021 Go to last post
  2. Distance from collet to table
    Started by Jonas, 19-09-2021
    19-09-2021 Go to last post
  3. linear bearing spacing
    Started by reefy86, 18-09-2021
  4. motor and gear ratio question
    Started by reefy86, 17-09-2021
    17-09-2021 Go to last post
    11-09-2021 Go to last post
  5. 3000x1500mm table drawing stage
    Started by reefy86, 03-09-2021
    3 Pages
    1 2 3
    08-09-2021 Go to last post
    30-08-2021 Go to last post
    27-08-2021 Go to last post
    19-08-2021 Go to last post
  6. NEMA23 pully and pinion
    Started by RonVais, 16-07-2021
    17-07-2021 Go to last post
    13-07-2021 Go to last post
    06-07-2021 Go to last post
  7. 1605 or 1610 for Inlays wood
    Started by gborislav, 24-03-2021
    05-07-2021 Go to last post
    30-06-2021 Go to last post
  8. Proximity switches or limit switches
    Started by chillybo, 08-12-2019
    6 Pages
    1 2 3 ... 6
    29-06-2021 Go to last post
  9. Help a fella build a cnc router😁
    Started by reefy86, 10-06-2021
    11-06-2021 Go to last post
  10. Where to buy cnc kits
    Started by reefy86, 08-06-2021
    08-06-2021 Go to last post
  11. Cable routing in V slot
    Started by Lol999, 20-05-2021
    21-05-2021 Go to last post
  12. Desktop gantry router for hobbyist
    Started by Soyb, 06-05-2021
    07-05-2021 Go to last post
  13. How to home the slave sensor?
    Started by Laszlo, 02-05-2021
    2 Pages
    1 2
    04-05-2021 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
