Home: Hotwire Cutting Machines
Discuss the building of diy cnc hotwire foam cutting machines, post your build logs/diaries here as well.
Threads 1 to 7 of 7
  1. BUILD LOG: Foam XL hot wire cutter
    Started by Boyan Silyavski, 04-08-2017
    5 Pages
    1 2 3 ... 5
    29-09-2017 Go to last post
  2. BUILD LOG: 2 axes hotwire cnc CAM software
    Started by paulus.v, 06-04-2017
    06-04-2017 Go to last post
    17-05-2016 Go to last post
  3. Smile Hot Foam cutter for RC aircraft
    Started by rckeith, 11-08-2010
    3 Pages
    1 2 3
    10-08-2015 Go to last post
  4. cnc 4axis hot wire mach3;
    Started by maikonesk, 04-08-2015
    07-08-2015 Go to last post
  5. BUILD LOG: CNC Hotwire 4 axis foam cutter
    Started by Skipsoaring, 04-06-2015
    2 Pages
    1 2
    29-07-2015 Go to last post
  6. BUILD LOG: Giant hot wire cutter
    Started by charlieuk, 04-01-2015
    2 Pages
    1 2
    05-01-2015 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
