Home: Items For Swap
Have you got an item you would like to swap for another item, are you looking to do a swap for an item, this is where you will find them!
Threads 1 to 9 of 9
  1. SWAP: Router
    Started by Stads, 03-01-2018
    09-11-2018 Go to last post
  2. SWAP: Bridgeport power feed
    Started by V8kid, 04-03-2018
    04-03-2018 Go to last post
  3. SWAP: CNC Wood Router
    Started by petesurrey, 29-12-2017
    29-12-2017 Go to last post
  4. SWAP: Gas bottles.
    Started by Wal, 19-03-2015
    27-03-2015 Go to last post
    29-05-2014 Go to last post
  5. SWAP: Hobbymat Lathe For CNC
    Started by palmerlad, 11-11-2013
    12-11-2013 Go to last post
  6. SWAP: Old Low res flat screen monitor
    Started by cropwell, 05-03-2013
    05-03-2013 Go to last post
  7. SWAP: 6mm Carbide CNC Router Bits for 3mm's
    Started by Fivetide, 02-12-2012
    04-12-2012 Go to last post
  8. SWAP: Looking to swap this USBCNC board
    Started by John S, 30-07-2011
    12-08-2011 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
