Re: Best anodizing guide?
Just tried one of these in a 500ml glass jar and it worked pretty well.
Attachment 22911
Took a good 10-15 mins to get up to temperature so would expect a lot longer with 5l tubs.
Runs at 12v and draws pretty much bang on 10A so 120watts.
Going to test wit 5L now!
https://s1.postimg.cc/1kwvscfnsf/IM..._133301345.jpg
The specific heat capacity of water is 4.184 joules/gram/deg, so to raise 5 litres of water from 20 to 80 degC, would take 1255200 joules (4.184 * 5000 * (80-20)), or 0.349 KWh. Now if you've only got 120W, that means it would take 2.91 hours (0.349 / 0.12) assuming you have zero heat loss.
However, unless you've got insulated containers, I'd doubt you'd ever get to 80degC.
m_c
Pretty much spot on. Tried it for the hell of it and got the top third of the water to 50c/
The rest stayed at 16c (workshop room temp). That was nearly 1 hour.
I am thinking 1000w min really as I don't want to wait too long for it and once one puts the part into the bucket the temp will go down quite a bit. So need it to be fast enough to recover from that.
Wondering if something like this would work?
https://www.aliexpress.com/item/900W...809794841.html
Keeping in mind a 5L bucket is around 200-220mm tall?
Not sure if these are designed for water but should be okay as long as the top is kept above water line I believe.
With something like that, I'd be making sure they were well earthed, and powered via a good RCD.
Have you had a look at any of the youtube videos for ideas?
I've got these saved in my watch later list
https://www.youtube.com/watch?v=BtYHcsq7s5A
https://www.youtube.com/watch?v=GccTVfMiIIo
https://www.youtube.com/watch?v=TGi-nqNnENE
It's been a while since I watched them, so can't remember exactly what they covered, but they must of contained something worthwhile that I never deleted them after watching them..
Thinking about it.
Cleaner, Dye and Sealer don't care if they are in a metal container?
Why not just use stainless cooking pots and put them on those cheap hot plates?
http://www.ebay.co.uk/itm/Single-Ele...EAAOSw-K9ZIxN4
As variable knob too so could potentially not even need thermostat controller?
Obviously not put the acid/lye in these, they still need plastic containers.
that's probably the way i'd do it personally yeah
Zeeflyboy
£11 for the hotplate, £8 for the 5L stainless pot. Total price is much better than Plastic tub plus heat element and controller...
JOGARA
From what I read you don't want the acid hot at all. Both the etch and/or the anodizing tanks should be room temp as those processes get hot when reacting/putting amps though them.
The Desmut, Colour and Seal should be heated though...
Going off the Ron Newman guide that m_c sent be lists this;
- Polish part using fine sand paper for shiny finish, or wire wool for matte (can also etch for a little longer for matte finish/hide imperfections)
- Cleaner @ 140F 5 mins
- Rinse (de-ionized water)
- Etch in Lye for 10-30 seconds @ room temp
- Desmut @ room temp 1-3mins
- Anodize at room temp based off 720 rule
- Dye @ 140F for 15s-15m
- Seal @ 180F
- Hang to dry for 24 hours
Other guides I have seen do mostly the same procedure, though one suggested using "Sodium Bisulfate/Sodium Hydrogen Sulfate" instead of Sulfuric which I guess is safer?
As for heating the buckets, I like the one you linked, but I am limited on power in my current workshop. Wont be in my new one till end of November.
Pretty much can't draw more than 3000w in total.
Thinking of getting a couple 12v ones that I can then use one of these cheap controller boxes with. Safer too as those immersion ones don't always have earth on the metal case.
https://www.ebay.co.uk/itm/172822446...r=471604592191 (This is 220v ones yes, they do 12v too)
If you have a mains thermostat just tape the probe to the outside of the bucket accuracy will be good enough.
I use these
http://www.ebay.co.uk/itm/220V-10A-M.../142426824134?
daily very reliable never had one fail over 5 years.
Desertboy
I presume that as long as the temps are in the ballpark around 120-140F then it is okay? Don't have to be so bang on?
[edit]
Multi buy, 3 for 2 https://www.ebay.co.uk/itm/292039778...r=591027809178
