you may need a new psu to meet the spec of the new spindle
I probably can't afford quality so would settle for Chinese.
Have you seen this? https://www.youtube.com/watch?v=jfryQr10nbo - someone has added a 1.5kW spindle to a micro router.
Thanks for that it's ust what I am aiming at.
Just a quick update to let you all know the outcome.
I ended up buying a serial to RS-485 adapter (less than £3 on fleabay) and downloaded a plugin to ebable Mach3 to control my spindle directly.
The new spindle is fitted and running and I was originally using a 5 gallon drum for a water reservoir but this didn't stop the temperature hitting the mid forties centigrade during the hot Easter weekend. I have to point out my workshop is upstairs and the room temperature was in the low thirties. As downstairs is always a lot cooler and having plenty of plastic pipe to hand I simply added about 15 metres of pipe to the outet and ran this downstairs then bak to the tank which solved the cooling problem.
Finally have the time to cut a job for which the spindle was purchased.
https://youtu.be/Ql1cm6tKDV0
