4 and 5mm steel plasma / laser cutting required, can send sheetcam files
I obviously won't send you .tap files, as don't know how your machine is set up.
can send sheetcam files, as I import hpgl into sheetcam from corel.
I can't plasma - only mill plastic, I can proto type what I need in 5mm foamex/plastic.
I then need it cut and posted to me. Can pay with pay-pal.
nothing is massive, merely little tabs and doo dads
so if you happen to be a hobbyist with a laser/plasma table with lots of scrap 4/5mm steel and you don't mind wandering to the post office...............
