Any ideas please cutter shank getting hot in festool router that seems real nice?
Hi Guys,
I brought a Festool router a while ago with some other bits. I ran it up to check it as I was going to sell it, not needing it. I was about to do a video to go with the descripton and got distracted! Anyhow, when I took the cutter out 1/2" shank it was pretty hot relitivly speaking after a few minutes. No nasty sound or bearing noise. Perhaps someone has an idea of the possible cause I can't see anything all that obvious. I would keep the router as I am a fan of Festool kit.
Many thanks and I hope a good time is being had.
Steve
Re: Any ideas please cutter shank getting hot in festool router that seems real nice?
Sounds like the bearing is on its way out!
When they go the collet end gets very hot!
Put new bearings in should only be about £15.00
Peter
Hi Peter,
Thank you for the reply. I think I may try the bearings, I guessed for the cutter to be getting hot so quick and the bearings would be noisy... Having said that I cant think of a more likely cause for the heat so I will get some bearings and have a go. I dont have much to loose in trying. Thanks very much I hope you are having a good festive break.
Steve
I wish you well.
I had to take my Elu router apart to find out what bearings were in there - the new bearings made such a difference.
The old bearings didn't make any noise - it just slowed down abit and that was very noticeable.
peter
suesi34e
Hi Guys,
Steve
Steve. When you ran it up was you cutting anything with it? If so the cutter could have been loose in the collet and that would have made it hot. Just a thought.
ptjw7uk
I wish you well.
peter
Thank you Peter and that is interesting. I shall get it down in bits and bearing ordered.
All the best
Steve
Hi Clive
Thank you for the msg. No I was not cutting anything and the cutter was tightend as per normal, good thought mind.
All the best
Steve
