Re: CNC Project - Guitar Neck (and the rest if I can get away with it)
Washout
Perhaps when the time comes (we both have projects to finish :) ) we could do a collaboration video as your machine's larger bed would save a lot of grief when it comes to cutting out the bodies.
Another cool build. Looking forward to that one taking shape..!
Wal.
Morning chaps,
More progress - nitro lacquer going on in this vid i.e. colour at last:
https://www.youtube.com/watch?v=xShT2vMbp8E
No doubt you have seen this guys work, but here it is for other forum members to be amazed at !
http://www.carverdoug.com/guitars.html
Cheers,
Rob
I wish I had your skill and patience Chris - I would love to build a Harpejji.
Hi Rob
Yes I have seen those guitars - they're really nice.
That Harpejji looks interesting and looks to be more 2D than a Fender design so should be doable if you can find a design/blueprint somewhere.
Chris
Washout
Hi Rob
Chris
The Harpejji board should be simple on a CNC router, it is just a matter of getting the fret distances right. The formula is something like 1/17 of the remaining distance to the bridge (but I would check it out properly). Electronics are more of a problem, I think you will need a sustain circuit for each string and that, in turn, means individual pick-up coils. The Chapman Stick works on a similar principle.
Rob
Yes makes sense - there's a couple of scale length/fret calculators out there (Stewmac and Manchester Guitar Tech iirc have them).
I must look into Sustainers as well at some point - I'm guessing they are similar to my beloved e-bow?
I've always fancied having a go on a Chapman Stick and didn't realise they use a separate pickup coil per string. That's very similar to the Gittler, which is another concept I've had in mind to incorporate into a guitar design.....so many ideas...so little time :)
Washout
If you want to trigger MIDI you need separate coils like on the Shadow SH35. Roland do a similar pick-up, but I can't remember the model number. Otherwise I suppose you can get away with standard guitar pick-ups.
My experience of MIDI guitar was a little fraught, to say the least, and I have the Shadow kit sitting on a shelf doing nothing for a number of years.
Rob
Hi all,
Some CNC for the Jaguars whilst I wait for the lacquer to harden:
Part 15a - CAD/CAM
https://www.youtube.com/watch?v=G1Vom8-0fdY
Part 15b - Machining:
https://www.youtube.com/watch?v=4o1eTtuUOu8
Hi all,
Latest video in the Jaguar saga is up, but no CNC this time:
https://www.youtube.com/watch?v=W6pJ3GJ6bNU
So by way of compensation here's another scratchplate machining video and CAD/CAM walkthrough from another guitar project I'm getting to the end of:
Fusion 360 CAD/CAM:
https://www.youtube.com/watch?v=dquZtcoCQM4
Machining:
https://www.youtube.com/watch?v=3Hpzyr95Kvw
Looking good Chris....Tele soon? 😋
