Davek0974
Hi Neil, sounding really good, BUT, please please please do not cut MDF or exotic woods without a good amount of extraction and/or a damn good breathing mask ( I am only assuming you don't wear a mask of course )
My reason for butting in here is that my father died a few years back following a long painful lung condition brought on by his love of making things out of MDF and exotic woodturning in the shed. He did have the dust extract that had bags on it but he still came out sometimes looking like a snowman!
Wood dust is nasty stuff.
It made me change my views on carefree metalwork as well, I spent a lot on serious extract for the plasma table, i've stopped powder-coating now, I have stopped turning cast iron on the lathe due to the dust and so on, it focuses the mind a bit.....
Dave
Hi Dave, I wear one of those twin filter painting breathing masks as I know MDF dust is very nasty stuff (I'm sure balsa dust is equally nasty)....look a knob but saves the lungs! I'm building an enclosure round the machine and there will be an extraction system (6" tube and for the enclosure which will also be for the lathe, welder and milling machines which will vent outside. The dust shoe will be connected to a vacuum cleaner (Nifilsk 30T vacuum) via a DIY cyclone dustbin.....
Excellent, I use one of those masks when doing a lot of grinding or finishing etc, keeps the black snot under control :)
Got fed up with the end cross supports....cut through one and dims between beams didnt change....will use external bolted braces....just gained some extra length on my machine 😁
http://uploads.tapatalk-cdn.com/2016...266cf7bdd4.jpg
Had a good purchase from eBay last week, a Camvac for under 1/3 its retail price. Its like new and works well.
http://uploads.tapatalk-cdn.com/2016...e6ddee7c5a.jpg
http://uploads.tapatalk-cdn.com/2016...0fe8d12467.jpg
Made a rough dust shoe out of 12mm ply and a bit of draught excluder. Just got to test it works ok before working out how to fix it on so there's access to change the bits and do the probing...
Any ideas anyone on how best to do this? I'm leaning towards neodinium magnets holding one side on...
http://uploads.tapatalk-cdn.com/2016...b3898c41d7.jpg
Put the home switches on X, Y and Z, wired back to the CSMIO IPM and set up in Mach3...all working as should but still need to put "targets" for them on the machine....
http://uploads.tapatalk-cdn.com/2016...65aaca0dc0.jpg
http://uploads.tapatalk-cdn.com/2016...7ece26e245.jpg
Ok so I've dome the homing switches and all work. Quick vid showing this.
https://www.youtube.com/watch?v=Vwje...ature=youtu.be
Seems to work ok.....however I've had to reverse the Z axis to get it to home and now its all to cock....if I try to do a tool zero with my touch plate then it goes up instead of down....just looking at the settings in Mach3 to see what I need to reverse/do but if one of you experts could point me in the right direction id be eternally grateful [emoji106]
Home Neg in Homing Limits screen.....
njhussey
Neil I take it that when the z moves down it is going -ve the homing switch at the top so it will home upwards +ve
Clive S
You're correct Clive, knew there had to be a setting but wasn't sure till I read the manual.
Set my park position too for changing bits and also for parking the gantry at the end of the day....slowly getting there with it.
Limits next, then enclosure, counter weight, proper dust shoe, LED lights...the list goes on!!
Neil are you sorted.?
Either Home neg are use the Reverse option but will depend on how axis is setup. one of them combo will sort you.
