Re: 5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
One thing I have noticed with the 6560 drivers is that on the one I have on a small drag engraver unless it's set for full steps the results are all over the place.
Full steps for me on this machine are fine as it's so low geared but in micro-step mode you cannot reply on repeatability on distance travelled. Overall I'm happy and the drivers are suitable for this wimpy machine but would not buy another board unless it was for an equally wimpy machine.
Hello,
I have bought 5 axis break board and 3 axis dispaly module.
Unfortunatly cable this display is not comapatibile with this board because male connection has different pins number and sequence cables should be different! Display module have the same 9 pins as breakout board.
Do you know what should be sequence cables from display module to breakout board?
Thanks,
lasek
Hello,
Thanks,
Hello Lasek: You should direct your question to "Lovelearn". He might help you with this problem. I know that you have to specifically purchase the pendant for that bob. They look the same on ebay but they are not!
I'm still building my machine and have not used the bob. Take care
