bolt on rail and block bearings or what ever - what have you
hello
can you post them too???
wanted no circular rail
thk style bolt to t-slot rail wanted
can be anything up to 32mm in width across the two dooberies
4 bits 600 long.8 bearings
bearings can be two peice whatsnames
also wanted long closed toothed belt,
3 motors and dives and psu
4 toothed pulleys
4 flanged idler pulleys
prefer a 20mm ish sized belt
Re: bolt on rail and block bearings or what ever - what have you
nobby
hello
It would be helpful if you stated the size etc. ..Clive
Come on your Man your not being charged by the letter give more info.! Using the thread title ONLY to ask a question smacks of can't be arsed and I for one will take the same attitude and think bollocks if you can't be botherd to tell me what you want I'm not asking.!!
nobby
hello
4 toothed pulleys
So you just want a bag of assorted bits? Posted to where ever will do. :rolleyes: ..Clive
Clive S
Come on Clive can't you see he wont's a Bag of "THINGY's". . for the "Dooberies" so he can fasten it to his "Whatsnames". .!!!
ok I have changed my mind and want
2 2525mm long 25mm wide 5mm pitch closed loop belts
8 pulleys to match the above, and what ever bore they are I want
4 motors to suit nema 23 small less than 3.1 the small ones not 115mm 425kn or 76mm long 3.1nm's
also want 4 idler pulleys
also want 4 bits of thk rail at about 2 foot long and the bearings for 10mm slots with the t-nuts and bolts.
also want a pilot arc machine torch not a p-80 the smaller one for about 50 shockers.
ok
two 2525mm 25mm wide 5mm pitched closed loop belts
eight pulleys to match with the edged rim
four nema 23's dual shafts not 76mm long 3.1nm the smaller ones
for 25mm idler bearings
four lengths of thk rail I do not care what width as long as the bearings are there and all four are at least 600mm long
nobby
Nobby I am sorry for you as I don't understand your requests and possibly others will not either.
How can you ask for a belt 2525mm long and pulleys to match without specifying the diameter and or the number of teeth and bore of them etc.
I would suggest that you sit down and think about what you want and start by putting a sketch up of what you are trying to achieve this way others (brighter than me) will understand what it is you actually want.
Please take this criticism in the spirit in which it is intended.:nonchalance: ..Clive
http://img.photobucket.com/albums/v2...psbe0086b4.jpg
simple H-bot
quad nema 23 - may go 17
45mm box t slot 600mm square - I have that
20mm thk rails need 4 bits 500mm long
want a 2525mm long belt 25mm wide 5mm pitched
need the pulleys to be about 16mm in diameter???
the pulleys I have seen state pilot bore? what actual size is that?
I reckon I only need a 15mm wide belt with nema 17's 5mm shafts, are the pulleys 5mm pilot bored
do they come with the grub screws
to be
