Automatic G-Code Generation Dovetails, Mortise and Tenon, Dados, Rabbets and More
These cuts are the foundation forfurniture and cabinet building and now they can be created in just afew minutes using Cambium Code Standard. A complete g-code programcan be generated very quickly by simply entering parameters for stocksize, cut size and placement, feed rates, etc.
This approach is backwards from thestandard process of designing in a CAD package, exporting to a CAMpackage, then generating a g-code file. Our method will save youconsiderable time, since you need only enter a handful of parametersand some standard text.
With Scripts to Generate Part Modelsin SketchUp
In addition to generating G-code,plugins are available for Google SketchUp which will automaticallygenerate the part in SketchUp.
The program CambumCode Standard is available for download at
http://www.cambiummachines.com/CambiumCodeStandard.html
You may also be interested in out toolfor setting up CNC routers running on Mach3, which is available at
http://www.cambiummachines.com/Setup.html
Thanks for checking us out - www.CambiumMachines.com
