Boxford pull studs for vmc190 tool holders
I think I’m correct in that Boxford used a Coventry quick change tool holder and then added a pull stud to it
I have the dimensions to make some side lock tool holders but I can’t find suitable pull studs
They have an M8 std metric thread so I guess I could turn some my own but as they appear to be hardened I think it would be easier all around if I could buy the pull studs
Does anyone have a source for these pull studs or if you good people happen to have any down the back of your sofas then I’m all ears
Cheers. Paul
Re: Boxford pull studs for vmc190 tool holders
Hi paul I hade the same problem as you so I made my own, If you use silver steel you can harden it your self.
hope this helps you.
reelman
Did you make them on a cnc lathe ?
If so would you consider sharing the G code please
Many thanks. Paul
Hi Paul, no I did them on a manual lathe
Ha proper old school
Looks like this is my next programming challenge
Cheers. Paul
Just out of curiosity,
Does Cam bam accommodate lathe jobs ?? or do folks code them from scratch?
