nema 23's wire colours for bi-polar parallel, can you check this is correct please
http://img.photobucket.com/albums/v2...psfcd644b1.jpg
line 5 earth
line 6 + limit
line 7 - limit
please and thanks
Re: nema 23's wire colours for bi-polar parallel, can you check this is correct pleas
The wire colours aren't standardised between manufacturers, so it would help to know which motor you're referring to. If it's this one then you are correct.
One simple way to check is if the motor gets harder to turn when you've connected the wires, then the wiring is definitely wrong.
Jonathan
yes they are the cnc 4 you ones
thanks
now, dip switches..............
