Combo ATC spindle BT30 3kw rate 220V/400hz max 600hz 18000rpm+ holder NBT30 + 4kw VFD
Spindle Motor Specifications :
Power : 3KW
Voltage : 220V
Current : 12A
Frequency : 400Hz rate, max 600hz
Speed : 12000rpm rate, max 18000rpm
Cooling Type : Water-cooled
Joint of nose : BT30 Taper
Lubrication : Grease
weigth: 16kg
Diameter: 100mm
Lengt: 400mm
Air pressure: 6kg/cm2
Combo T inclue spindle 3kw + 6pcs NBT30 ER25 holder + 6 ER25 ( 3mm, 4mm, 6mm, 8mm, 10mm, 12mm) + Spindle holder 100mm + VFD 4kw BEST FC300 + airtac solenoid + airtac air regulator
https://www.ebay.com/itm/183901430506
contact
[email protected]
whatsapp 840903306934
Please feel free to contact me
Thanks and Best Regards
https://live.staticflickr.com/65535/...3937f843_b.jpg
