Small product case - Aluminium - 160 cases x2 (front and back)
ON HOLD - We are evaluating if we can manufacture these ourselves or not. Will open up for quotes again soon if we can't.
All files located in .zip bellow.
50x Top and Bottom
AIO top.stl
AIO bottom.stl
90degree angles can be milled with 3mm bit.
Curved bit at the top can be stepped at 0.1mm using 3mm bit. Yes 3mm floor is fine.
3 square holes can be milled with 2mm bit on the 90 degree corners.
1mm chamfer required on rear side around the edges and 3 holes.
The 4 pillars are actually a drill hole size of 2.5mm not 1.6mm, will update later.
75x Top and Bottom
RP top.stl
RP bottom.stl
3 square and large rectangle holes can be milled with 2mm bit on the 90 degree corners.
1mm chamfer required on rear side around the edges and 3 holes and large rectangle hole.
The 2 pillars and other 1.6mm hole are actually a drill hole size of 2.5mm not 1.6mm, will update later.
35x Top and Bottom
S top.stl
S bottom.stl
1mm chamfer required on rear side around the edges.
If you have the ability to tap on machine, all 2.5mm holes can be tapped M3, rear large hole on bottom parts is 1/4-20.
I can do the tapping if it adds to the cost too much.
https://drive.google.com/open?id=1F7...YyKvIIJk2HwR31
