Motor mounts (idk how they go mounted with the motors!)
http://i47.tinypic.com/28ckrqu.jpg
I think i will design the a similar frame like this:
http://www.mycncuk.com/forums/router...ed-router.html
I will post it as soon as i have it designed!
if you have drew them you have far too much time on your hands :P good luck with the build sorry i cant help with anything i'm still too new
hahaha well, both draws didnt take much time to do.
Thanks anyway! :)
Base, using 50X100 square steel , 800mm and 600mm for using 790 X 590 linear rails
http://i48.tinypic.com/2ikpem1.jpg
What do you think about sizes?
Made rails and blocks.. this week i will make more parts. any input, feel free to comment!! :)
http://i45.tinypic.com/35iqet3.jpg
http://i48.tinypic.com/2na0ftv.jpg
splendid, this is where drawings start to earn their keep...
if you are hoping to use nuts on those rails it may pay to have the long box sections open instead of the short ones like you have drawn
it will still be a pain to get nuts in but not impossible :)
run the rails all the way to the back of your frame in light of the fact that your Z axis is likely to have an overhang that will push your cutting aria forward too the inside of the aperture of your frame
you may need to extend the frame to keep the Z inside the frame at its furthest reach… easy enough to amend as the drawing develops :)
yes, holes go to the other side, it's not possible to see in the draws :)
About to run the lighs to back, ok, noted it1
Really the area i need is 600X400mm, in think i will go a bit oversize since i designid it with 800X600 and 790X590 rails..
Thanks for your help Blackburn!
Stunning drawings!
Would nutserts be of use for fastening the rails down? CNCzone.com-The Largest Machinist Community on the net! - View Single Post - CNC Plasma Cutter Table Build 3x2m including THC and watertable and here
Hi Walterronny, could you let me know what software you are using for these images they are superb!
