Small round of aluminium cases. Small parts, 50 in total for first batch. 110x50x15m
Looking for quote on getting my case machined.
Odd looking thing yes but it is designed around housing electronics.
Here is a ZIP of the STEP and STL files as well as drawing sheets.
https://drive.google.com/open?id=1rQ...uR_9sKlkhwJG_o
Parts are no bigger than 110x50x15mm.
They will require machining on both sides as well as a rear hole cut out for sockets.
Don't require tapping but if you are able to do it on the machine then might as well tap the M3 and 1/4-20...
I need 25 of each.
