im based up north in manchester was hoping to do kitchen units and bedroom furniture but at the moment can not get away from shopfitting. i have found the parts manual but still could do with a user manual
thanks for the reply
will do, i might have to scann it ( its big ), so i will do it friday or saturday.
Its ideal for kitchen and wardrobes. there are some special codes as part of the g-code, but nothing unusual. i think i have a copy of the setting disk and some other bits you will find usfull.
Tips
when servicing bearings and so, the parts manual does not always show you all clips and screws. I got stuck on the main X screw baring for a while. they are easy enough to service though
2. Take time to make sure you set the feet properly, so the the weight is spread over the full lenght ( stop any slight twist on long jobs ) even if you have had it stood for a while, true up the shape by adjusting the feet
final,,, saftey barriers and e-stops are a must on these type machines... they look fabulously dangerous whilst in operation. massive green iron comedy splatting type cnc machines
Thanks for all the help george are you based any where near me
