Looking for a copy of Burny/ITT WinAMC software for an AMC4 controllor/laser cutter
Hello all,
Title kind of says it all. I am trying to help a fried with a laser cutter and older AMC4 controller.
I would like to get a copy of the WinAMC software and build some vitrtual test control panels.
Any help would be gereatly appreciated.
Thanks in Advance.
Re: Looking for a copy of Burny/ITT WinAMC software for an AMC4 controllor/laser cutt
Have you tried contacting Burny directly? I doubt you would manage to pick this up otherwise but I do seem to remember someone else talking about this a while ago on here. A search of the forum might bring it up.
Just spoke with a very helpful Rep at Burny. They adivised moving forward/off the AMC and using current technology rather then integrating it.
Will most likely reseach developing a Parrallel control system with Bob's and LinuxCNC or Mach3 option.
This would allow the cutter to run on the existing legacy Design/Plot/AMC Controller as well as have the option to use a more open control CAM system.
Will need to research the controls needed for the cutter.
I glad its getting sorted out. I have dealt with burny a lot in the past and always found them to be helpful. You also have the option of USBCNC as well for your control software and hardware.
Hi, I have been running my Wessel (ex pcb drill/router) as a highly accurate router for about 10 years with an AMC 4 controller (servo version) and have never had any problems. I do use WINAMC (for drip -feeding and config files to over-ride the flash memory) which I believe was a free download at some stage, but has now been removed. There is a possibilty that I can get hold of a copy if you decide to go down that route. G.
Sorry, but I have just been told that WINAMC is no longer available, but that the Burny version will do the same job (maybe better). G.
Do you still have a copy of WinAMC Geoffrey?
Hi i have a copy of WinAMC but but it needs a user name and password which i don't have
Hello Evrybody
Im from Turkey,İstanbul.
We hava a cnc and winamc inside.I had a tunder breake and the winamc had flown.
How can i havwe that.Would you send me .
Best wishes from İstanbul.
Erol topcular.
