6 Attachment(s)
Re: The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
Spindle: 1 Me: 0
It's a pita because you must fabricate your tools, and even they easily breaks (only 2.5mm pins...). You must heat at least 3 minutes in full power with your heater before trying unscrew this "#&@% full of holes". I enlarged them to 5mm,. But after this first victory, there's another flange. End of the story for me.
Attachment 27398
Attachment 27399
Attachment 27400
Attachment 27401
Attachment 27402Attachment 27403
The 6002 bearing must have the large side pointed to the top. It's not a radial bearing.
Hi Jonathan,
I have just put together WorkBee 1000 x 1000 mm CNC machine. I am totally intimidated by the electronics. I purchased this machine from a firm in China and the directions for electronics are either nonexistent or (for me) undecipherable. Can you put me in touch with anyone who can walk me through this electronic challenge?
I have a Huanyang GDZ-80-1.5 11V 1.5Kw 5A 400Hz spindle, an HY01D511B , an LRS-350-24, a UNO cardstepper card.
Thank you for your time.
Re: The Common 2.2Kw Chinese Spindles - Info, Setup and Advice + More !
I'm using a 400Hz 220V 24,000RPM Spindle motor from Vevor
Can anyone remind me of the Mitsubishi FR-D720 parameter settings for this motor please.
