Draftsight to sheetcam mach 3 imported drawings are increasing in size
I drew up a flange in Draftsight it was 190mm os saved it to sheetcam then loaded to mach 3 it seem to increase ten fold.my machine always seems to what to start of the plasma bed too.thanks for any help
Sent from my SM-G361F using Tapatalk
Re: Draftsight to sheetcam mach 3 imported drawings are increasing in size
whensparksfly
Is one set up in mm and the other in cm?
How do I check
Your code should have a G21 for Metric or a G20 for Inch, it will be in the first few lines of code but it's easy to search for,
- Nick
It says g21
Your G-Code is set to metric, that should also cause Mach3 to switch to metric even if it's previously set to inch.
Post the code up here and let's have a shuftie
- Nick
N0010 (Filename: nigel first flange final.tap)
N0020 (Post processor: Mach3.scpost)
N0030 (Date:24/05/2016 Time:01:13:16)
N0040 G21 (Units: Metric)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: nigel first flange)
N0080 (Operation: Outside Offset, 0, T1: Plasma, 0 mm kerf)
N0090 (Plasma, 0 mm kerf)
N0100 T1 M06
N0110=C2=A0 G43 H1
N0120 G00 Z20.0000
N0130 X95.8839 Y95.8838
N0140 Z10.0000
N0150 G01 Z1.500 F100.0
N0160 F440.0
N0170 X94.1162 Y94.1161
N0180 G00 Z20.0000
N0190 Y95.8839
N0200 Z10.0000
N0210 G01 Z1.500 F100.0
N0220 F440.0
N0230 X95.8839 Y94.1162
N0240 G00 Z20.0000
N0250 X95.0000 Y20.0001
N0260 Z10.0000
N0270 G01 Z1.500 F100.0
N0280 G03 X95.0000 Y20.0001 Z1.5000 I-0.0000 J74.9999 F440.0
N0290 G00 Z20.0000
N0300 X94.6339 Y4.9339
N0310 Z10.0000
N0320 G01 Z1.500 F100.0
N0330 G03 X94.6339 Y4.9339 Z1.5000 I0.0000 J4.6999 F440.0
N0340 G00 Z20.0000
N0350 X155.9880 Y29.3121
N0360 Z10.0000
N0370 G01 Z1.500 F100.0
N0380 G03 X155.9880 Y29.3121 Z1.5000 I0.0000 J4.6999 F440.0
N0390 G00 Z20.0000
N0400 X182.1339 Y89.9339
N0410 Z10.0000
N0420 G01 Z1.500 F100.0
N0430 G03 X182.1339 Y89.9339 Z1.5000 I0.0000 J4.6999 F440.0
N0440 G00 Z20.0000
N0450 X157.7557 Y151.2880
N0460 Z10.0000
N0470 G01 Z1.500 F100.0
N0480 G03 X157.7557 Y151.2880 Z1.5000 I0.0000 J4.7000 F440.0
N0490 G00 Z20.0000
N0500 X97.1339 Y177.4339
N0510 Z10.0000
N0520 G01 Z1.500 F100.0
N0530 G03 X97.1339 Y177.4339 Z1.5000 I0.0000 J4.7000 F440.0
N0540 G00 Z20.0000
N0550 X35.7798 Y153.0558
N0560 Z10.0000
N0570 G01 Z1.500 F100.0
N0580 G03 X35.7798 Y153.0558 Z1.5000 I0.0000 J4.7000 F440.0
N0590 G00 Z20.0000
N0600 X9.6339 Y92.4339
N0610 Z10.0000
N0620 G01 Z1.500 F100.0
N0630 G03 X9.6339 Y92.4339 Z1.5000 I0.0000 J4.6999 F440.0
N0640 G00 Z20.0000
N0650 X34.0120 Y31.0799
N0660 Z10.0000
N0670 G01 Z1.500 F100.0
N0680 G03 X34.0120 Y31.0799 Z1.5000 I0.0000 J4.6999 F440.0
N0690 G00 Z20.0000
N0700 X95.0000 Y-0.0000
N0710 Z10.0000
N0720 G01 Z1.500 F100.0
N0730 G02 X95.0000 Y-0.0000 Z1.5000 I-0.0000 J95.0001 F440.0
N0740 G00 Z20.0000
N0750 M05 M30
That code should not run no expert but line 110 looks incorrect
N0110=C2=A0 G43 H1
Your probibIty will run not sure if it will finish.I just wondering is it the mach 3 plasma table setup
I am no expert but looks ok to me apart from 2 "=" characters on 110 while they are there it should not do anything.
As I read it it cuts inside first then bolt holes then external 20mm offset from internal
