Thread: 1200mmX900mmX170mm 4axis cnc
15-04-2018 #201
15-04-2018 #202
No Sir, It was working fine as a VFD before I took it out. My next step is to double check the connections, but not today, I have had enough. I will start fresh tomorrow, but tonight is beer, roast chicken and relax.
This will be a new thread I'll bet. I don't want to hijack yours !!!
15-04-2018 #203
Neat layout.
Minor observation:-
It can be a good idea to wire a bleed resistor across the output - nothing too big, but enough that you're not holding a substantial and dangerous charge long after removing the power.
Also, there's some concern with the use of screw terminals particularly with high-current circuits and when vibration may be present that the screws can loosen over time.
15-04-2018 #204
15-04-2018 #205
15-04-2018 #206
Value?, pick a number. I recently ordered 1500 Ohm, 7W wirewound resistors for an 80V supply. Just remember Ohm's law - you can determine the power rating from the voltage and chosen resistor value (P = V*V/R) - the lower the value the quicker it will discharge, but the beefier the resistor needs to be, and the more energy you throw away.
The Following User Says Thank You to Doddy For This Useful Post:
15-04-2018 #207
15-04-2018 #208
I'm going to engage pedant mode for a moment.
It's not to do with volt drop, it's mostly to do with the risk of harmonics.
Stepper drivers are essentially a complex switched mode power supply, which means they don't draw a constant current, they're constantly switching at high speed. If you place multiple of these on the same wire, then you risk harmonics, which is where multiple spikes at the same time lead to high voltage spikes, which can destroy electronics very quickly, and in extreme cases will burn out the wiring, even though the total current may be well within the current limit of the wiring.
Off course the latest drivers are far more likely to contain some internal filtering to help avoid noise being propagated into the supply, as part of them meeting various approvals, which should avoid any harmonic problems.
Avoiding daisy chaining also helps minimise any potential damage from a failed connection, as a connection failure during deceleration is very likely to result in an overvoltage failure, with resultant smoke release from drives. By having them wired direct, the worst case is one drive fails, but if daisy chained, you risk every drive after the bad connection failing.
Personally, I always wire drives directly to the main smoothing capacitor, as it avoids having any more connections in the wiring than needed.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
15-04-2018 #209
Trad English Roast Chicken, Stuffing, Roast potatoes, parsnips and braised carrots, None of this forrin stuff
If you use a 5k bleed resistor, you will not have enough current going through it to significantly affect the PSU in operation and a 2W resistor should handle the current. I don't know what capacitor value you have but 5K will bleed down fast enough.
15-04-2018 #210
A bleed resistor might be useful while you are testing, but once you have a driver or two wired to the power supply, they look like a waste of time. When I checked my machine, the stepper driver power supply was down to a few volts within seconds of cutting power. Any resistor that drains down faster than that is going to need to be a fairly high wattage item, and is going to produce more heat than you probably want in the control box.
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
