Thread: New start
Page 7 of 41 FirstFirst ... 5678917 ... LastLast
  1. #61
    ah when you said ready for new holes with the new tap I thought your problem was solved so assumed the old tap was extracted!
    Shame it's all steel, you could have dissolved the old tap if it was stuck in aluminium. I don't suppose you have suitable welding equipment to spot weld something to the top of the tap?
    edit - oooh, useful http://www.waltontools.com/products/remvtap.htm
    double edit - some ideas here? https://www.youtube.com/watch?v=IZsjj7pqBXc
    I had a look at similar tapextractors today but they were only for standard taps with 4 straight grooves. My tap is the spiral kind..
    So no go on the extraction ;)
    Only have a stick welder right now and it's not really a good idea with the epoxy already applied :D
    But I think it will be okey in the end anyway!
  2. #62
    New question!!
    All you hiwin users get the sexy green dust guards to put in the rail screw holes. For my noulei rails I got red ones.. they have a really tight fit but no stops or nothing so they easily get pressed down into the holes.
    Is it the same for hiwin?
  3. #63
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    New question!!
    whats wrong with putty
  4. #64
    New question!!
    My clone rails and my original rails never came with caps but mounting my rails at right angles so not so worried about them becoming fouled up.
  5. #65
    Desertboy since you have use both Hiwi rails and some other similar, have you notice difference in quality? What about tollerance between rails and sliders ?
  6. #66
    The rails feel identical between the originals and clone but the clone rails don't seem as high quality metal but that's really a gut thing only time will tell. Tolerance on the cheap rails seems spot on just as good as the originals.
    The clone rail was £100 for 2* 1.5m and 4 carriages delivered! so I wasn't expecting it to be as good but it does feel real nice based on initial impressions I can see me buying more of the clone rail down the line for a plasma cutter table.
  7. The Following User Says Thank You to Desertboy For This Useful Post:
  8. #67
    Thanks for the reply, can you point me a seller? Or anyone else can give info about a prompt seller.
  9. The Following User Says Thank You to Nickhofen For This Useful Post:
  10. #68
    Took me a while to find the ebay listing bastards have put them up £40 now! Wish I'd bought more of them but will keep an eye on them to see if they reduce the price again at some point.
    http://www.ebay.co.uk/itm/15-1500mm-...N/282574638774
    They are out of stock but they are always out of stock lol not surprising at the price but they seem to restock monthly. If you're getting crazy delivery prices send them an email my friend bought a set to US and ebay was quoting him £500 delivery lol but when he contacted them it cost him $30 for P&P. They seem to sell out in a week after each restock so probably worth sending them a mail if your interested or you'll miss it.
    It's free delivery to UK which is nice.
    The price they have the plasma cutters up for
    http://www.ebay.co.uk/itm/CUT50-Plas...item5d746be6a1
    I think I will be buying 2 sets of 1.5m rails and the cutter from them but that'll be after Xmas more interesting things to build and do first ;)
  11. The Following User Says Thank You to Desertboy For This Useful Post:
  12. #69
    OK I will text them, 500 for delivery seems a little bit high, lol!
  13. #70
    Small update :D
    The extrusions for the gantry has arrived. YEEEAH! !
    Have tried to paint a few parts and tapped alot so maybe there will be good progress from here ;)
    Some pics below of test fit fitment.
    Have not joined the extrusions in their L formation yet only screwed in the X plates
    vårbilder gratis
  14. The Following User Says Thank You to Nr1madman For This Useful Post:
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
