Page 2 of 6 FirstFirst 1234 ... LastLast
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 23 Minutes Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    (probably why it doesnt work lol)
    Ya could be right there, start with contacting Rhonmac.
    Phill
    do you use Aspire yourself Phill? if you do would it be possible please for you to output me a simple file 100mm X 100mm project size and a pocket of 60mm X 60mm depth of 30mm tool size 8mm mill, that way I will be able to check if my software is working correctly. Thanks not to worry if you cant or dont use.
    phill05's Avatar
    Yes mate on it now
    awesome thank you
  5. #15
    cheers Phill will let you know tomorrow
  6. The Following User Says Thank You to woodworker For This Useful Post:
  7. #16
    Hi Phill
    Same unfortunately the tap file cut ok for around 5 cuts then went left by approx 20mm (the bit doesn't like being shoved across a thick piece of wood) and the second file cut to the right approx the same at least I can rule out Aspire as the culprit, going to make a phone call me thinks.
  8. #17
    Solved turns out my Mach 3 copy is corrupt what did I expect as it came with my long dead Chinese laser machine so I now need to purchase a new Mach 3. Big thanks to Phill for going beyond the call really helped me nail down the issue.
  9. #18
    If you purchased a proper licence, then you should be able to download Mach3 and use the same licence. If the licence came with the Chinese laser, then it is probably a 'pirate' and the download won't work with it.
  10. #19
    yeah should have realised :) reg to papa somebody just have to wait for payday now.
  11. #20
    papa fabio strikes again.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. 3d carving oak
    By Mikeb in forum Woodwork Discussion
    Last Post: 24-03-2014, 10:22 AM
  2. V bit carving
    By Mikeb in forum Tool & Tooling Technology
    Last Post: 20-02-2014, 04:52 PM
  3. tools for 3d wood carving
    By chris in forum Marketplace Discussion
    Last Post: 18-01-2014, 04:23 AM
  4. 3d carving bits
    By drut in forum Tool & Tooling Technology
    Last Post: 04-07-2013, 01:03 AM
  5. Microcarve picture carving software
    By cnctoybox in forum CAD & CAM Software
    Last Post: 26-03-2012, 07:00 PM
