Thread: Shims
    Anybody else on the forum as cheapskate as me, that uses cut up drinks cans as shimming?
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I thought that was the norm
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    I've used shimming foil in a couple of places, £5 a roll.
    I use the shimming foil found in the kitchen -12.5p/metre.
    AndyUK's Avatar
    Well yeah - I've used that in a few other places. I just don't think Tesco's dimensional tolerances are up to snuff.... Perhaps I'm just a snob?
    Edit: Plus this stuffs bronze. Much fancier.
    It has it's uses. When I was leveling the gantry on my machine, I couldn't find any "proper" shim stock that was thin enough to get it nuts-on. Dug around in the fireproofing box and found a roll of appallingly thin kitchen foil from the local pound shop, just the job
    I'd use fag paper if it got the job done. The main thing is it doesn't change size.
    Aluminium cans are good for shims, with aluminium foil nicked from the kitchen for the decimal places
    Have you tried the Waitrose product?
    Is your bronze Spring Tempered, Grade A, Rockwell 30T 76-80 or just the ASDA cheap stuff ?
    Seriously though - if I am shimming up with foil, I check the results after reassembly, and only use it where it is actually suitable.
    I have seen fag paper used to lift an edge on an angle grinder. That was 60 years ago, it is amazing what impresses you as a kid, enough to make a lasting memory.
