Thread: Build and Intro
06-02-2014 #41
That is some really nice work - I have been toying with replacing my kitchen with some CNC work (will need a bigger machine), but those furniture pieces are very inspiring.
The Following User Says Thank You to Washout For This Useful Post:
06-02-2014 #42
Melamine faced chip board is a good idea. I can't remember where I saw it now but after cutting this guy covered the board with black dye. The dye stained all of the cut sections but wiped clean from the melamine leaving a very high contrast design.
15,000 holes for each door! Wow! So that's a minimum of 30,000 z movements? 60,000 for both doors.... Amazing.
I wonder what kind of strain that puts on the z screw?
Jim
07-02-2014 #43
I was thinking about using contrasting hardwood veneers, thicker than normal veneer.
07-02-2014 #44
I think this may be the video you're thinking of...
Aventador Halftone cut by DIY cnc router - YouTube
I have tried this but couldn't get all the black stain off the melamine. I tried ink, watered down ink, acrylic paint and water based paint, all left a grey/light black on the white. The program mentioned above also has an option to do images in the wave pattern.
With respect to the images yes there's a lot of stopping and starting, from memory it was around 45,000 lines of code. I wouldn't be too concerned about the ball screw, that should be alright. My main worry would be with the connection between pulleys and ballscrew with respect to how well they are mounted onto shaft. If you have read my thread you would know I had a few problems with the pulleys coming loose on shaft and chewing the shaft up. I was always checking that the set screws are tight. Now its been a while with no loosening I can be pretty certain it should stay that way.
07-02-2014 #45
That's a great video. With regard to getting stain off melamine, maybe before you start you could paint it with a thin coat of PVA, cut it, stain it, then the PVA + stain should wash off with water leaving the melamine clean.
07-02-2014 #46
Yes, thats the one.
That's a shame, seemed like it could be a good method. I wonder if maybe there are different types/grades of melamine?
I haven't read your full thread, I will have a look. I too have had issues with with couplings coming loose.....when mine came loose the spindle dropped and almost set fire to my garage! (To be fair it was my fault for not keeping an eye on the machine while running)
Interesting idea eddy. The other example shown on Jason dories site is to cover the board in self adhesive vinyl, cut, spray paint, remove the vinyl. Seemed to work quite well.Last edited by cncJim; 07-02-2014 at 12:33 AM.
07-02-2014 #47
07-02-2014 #48
Lol! At first I was going to write "sticky backed plastic" but thought it sounded a bit naff!
07-02-2014 #49
Now that I looked at that video again it looks as though he didn't get all the ink off the melamine either. Hard to tell though. Some of those ideas sound good, I will give a shot when I do it next.
Just uploaded this vid, Quality isn't very good but you get the idea. Set it at highest quality (240p)
Halftone image CNC DIY router - YouTube
07-02-2014 #50
NEW MEMBER: Intro
By vt356b in forum New Member IntroductionsReplies: 5Last Post: 02-09-2013, 11:39 AM -
NEW MEMBER: New here - new intro
By ChrisTerry in forum New Member IntroductionsReplies: 3Last Post: 05-08-2012, 11:09 AM -
NEW MEMBER: Intro
By Ian Hart in forum New Member IntroductionsReplies: 2Last Post: 22-02-2010, 06:06 AM -
NEW MEMBER: Hello / Intro etc
By pjm in forum New Member IntroductionsReplies: 2Last Post: 23-01-2010, 05:59 PM -
NEW MEMBER: Intro...
By Davidh in forum New Member IntroductionsReplies: 1Last Post: 29-08-2007, 01:58 PM
