Dave can you post the Aspire file up?
I have just drawn a simple circle in Aspire and put it through the MAch3 post without any problems.
Have you done the cad in Aspire or imported from another cad package there is a command to close vectors with a smooth curveLast edited by Clive S; 09-07-2016 at 10:59 PM.
09-07-2016 #2
Daft question, maybe, but did you draw the circle in Aspire or import a dxf from elsewhere? I had similar problems a little while ago because I had saved the dxf in the wrong version so it ended up as a series of line segments rather than arcs.
10-07-2016 #3
Hi
the file was just a quick mess about for testing the motion on my mill conversion project.
It was all done inside Aspire.
File attached
Test junk.zip
10-07-2016 #4
I just made a similar file in my CAD app and converted it in Aspire and its just as bad, converted in SheetCam and its perfect - about 15 lines of code :)
Seems to be an aspire bug?
10-07-2016 #5
10-07-2016 #6
Yes i drew it in aspire, same post here although i tweaked it a little to suit my machine but only in the end code i think.
Aspire does the same thing when i import a circle from my CAD app.
10-07-2016 #7
I'm not familiar with Aspire but most CAM applications have an option for lines or arcs as some old controllers don't support arcs.
If you select a "lines, not arcs" output option in CAM the results are as described,
10-07-2016 #8
Aspire v4.5
By m.marino in forum VectricReplies: 6Last Post: 16-05-2015, 04:44 PM -
CNC router occasionally makes jarring noise and home jumps when it does this. Help!!
By itsmillertime in forum Machine DiscussionReplies: 47Last Post: 13-02-2014, 11:49 PM -
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM -
Cutting out a circle
By Martin Paul in forum Machine DiscussionReplies: 2Last Post: 19-04-2011, 12:58 AM -
Aspire !!!
By james mcgrew in forum CAD & CAM SoftwareReplies: 2Last Post: 17-01-2009, 02:16 AM
