    Hi All
    I've been running my homebrew plasma table for a couple of years now and I'm still really enjoying it, however, there looks like there could be a requirement to cut some 3mm birch ply.
    What parts would I need to convert my plasma machine to a laser machine?
    I've seen super fandangled cooling systems, power supplies, tubes and mirrors etc and I can't get my head around what is actually NEEDED.
    I believe a 40w laser would do the task - can anyone confirm\reject this?
    Should I decide to beef things up (laser wise) what is needed to cut say 6mm mdf? (in for a penny in for a pound!)
    Any advice greatly received even if it is "don't bother buy a Chinese thingy"
    ATB and many thanks
    Danny
    I am a firm believer in one machine for one process. So I would suggest you buy a cheap chinese laser cutter even if it is at 40W. I went with the 50W which was slightly dearer but had on board controls.
    In terms of what you would need to convert a plasma to laser:
    Powersupply 100
    laser tube ~300-500
    optics 100
    holders for the optics ~100
    Waterpump or chiller for the tube 10-500
    fume extraction method 20-1000
    https://emvioeng.com
    Thanks komatias
    I must admit I am with you on the one machine per task. But for a first foray into laser I would be prepared to compromise for a short time.
    Thanks for the break down that is fab.
    Your 50w machine. ...What is the max thickness mdf it will cut?
    This could be the way to go.
    Danny
    Quote Originally Posted by gr8fun View Post
    Thanks komatias
    Danny
    Danny,
    MDF is a shit material to laser. There are specific ones that work better though but the fumes they give off a sickening. During cutting the glue that holds the particles together melts and runs leaving a very ugly finish on the side. That is why laserply is better in general.
    My machine can cut through 6mm laserply at 5mm/s and 4mm at 10mm/s at 56% power.
    When it comes to pine, you can really blast through it with very little power as it is a less dense material. Have done up to 12mm pine but you do lose the crisp edge due to the beam being out of focus through most of the thickness.
    Thank you!
    That's good to hear. Sound advice on the mdf. And a 50w seems to be more than enough. Now off to the boss (wife) for budget :-o
    :-D
  1. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 11:36 AM
  2. RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
    Last Post: 07-03-2014, 06:56 PM
  3. FOR SALE: redsail c150 laser - ideal plasma conversion
    By nobby in forum Items For Sale
    Last Post: 01-03-2014, 05:17 PM
  4. Replies: 0
    Last Post: 18-09-2013, 04:28 AM
  5. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 03:30 PM
