    Hello All, I want to start developing my own CNC machine and I found different designs in the internet.
    I want to know how to choose the best design and why should every design be better in some field.
    I want to read more about this and need your help
    Post the designs your considering as options?
    What is your chosen field?
    .Me
    .Me
    .Me
    I need comparison to choose, My field is Computer and Control
    Sorry if i didn't understand your question well
    Quote Originally Posted by ammaratef45 View Post
    Np, you said you found designs on the Internet? Share/post these designs for us to review ?
    What materials do you want to cut with your new machine?
    Do you want help choosing a machine or just advice on the structure of a machine?
    .Me
    .Me
  5. The Following User Says Thank You to Lee Roberts For This Useful Post:
  6. #5
    Each machine is designed to cut different types and sizes of materials. For example:
    1) Engraving small objects -
    Type: Fixed gantry, moving bed
    Movement: Ballscrew, Leadscrew, or direct belt
    Feedrate: Low
    Stiffness: Low
    Rails: Supported round
    Accuracy: Low
    2) Large wood or plastic sheets -
    Type: Moving gantry with side legs
    Movement: Ballscrew, or more likely rack & pinion (size and feed makes ballscrews less desired)
    Feedrate: High (to cut properly and prevent burning)
    Stiffness: Medium
    Rails: Supported round, or profile rail
    Accuracy: Medium
    3) Large aluminium parts-
    Type: Moving gantry with raised X-axis (no side legs on gantry)
    Movement: Ballscrews
    Feedrate: Medium
    Stiffness: High
    Rails: Profile rail
    Accuracy: Fairly high
    4) Small aluminium/steel parts -
    Feedrate: Medium
    Stiffness: Very high
    Rails: Profile Rail
    Accuracy: High
    (or convert a milling machine to CNC)
    You can argue the details for the above but the point is that depending on what you want to cut, how big it is, etc. it will have conflicting requirements. That is why there are so many different machines out there. If you use a machine to cut a different part to which it was designed it will either be slow, dull the cutter, or not give the accuracy you need.
    As Lee says, tell us the sizes and materials you want to cut and that will help narrow down the best options.
  7. The Following 2 Users Say Thank You to routercnc For This Useful Post:
  8. #6
    Feedrate: Low
    Stiffness: Low
    Accuracy: Low
    Stiffness: Medium
    Accuracy: Medium
    Feedrate: Medium
    Stiffness: High
    Rails: Profile rail
    Feedrate: Medium
    Rails: Profile Rail
    Accuracy: High
    Great that help me start, I will come back to you guys if I had been stuck again
  9. #7
    Tell us what you will use it for, cause there are many hybrid designs and variations also. Apart from that you will have to understand that machine frame, motor and driver choice, linear movement parts are inter dependent and must be chosen at the same time. Not build frame then choose motors...
    project 1 , 2,Dust Shoe ...
  1. Y-Axis Designs
    By Cyclonit in forum Gantry/Router Machines & Building
    Last Post: 24-06-2014, 02:20 PM
  2. Mechanical Advice
    By Pheet in forum Gantry/Router Machines & Building
    Last Post: 06-10-2013, 02:39 PM
  3. CNC Mechanical Service / Installation Enginner
    By Simon@Alecto_Recruitment in forum Opportunities Available & Sought
    Last Post: 03-07-2013, 04:35 PM
  4. SBR v TBR - Comparison
    By Karl in forum Rails, Guideways & Bearings
    Last Post: 30-05-2012, 12:02 PM
  5. Breakout Board Comparison
    By 200thhorseman in forum Gantry/Router Machines & Building
    Last Post: 27-03-2012, 12:28 AM
