    hi. I have been playing around with cnc for a year now and have not made one part. this is what I wish to do and this is what I have so far to do it. I wish to make a few steel parts for my 0 gauge locomotives. these would be things like connecting rods that are just under 2mm thick and 5mm wide and 50mm long. so not large parts.
    I have solidworks 2016 software to draw and design the parts needed. I do not have any CAM software and for what ever reason solidworks HSM works as stopped working and I don't feel like paying their asking fee for my hobby use. so I need a good CAM software program that is cheap or free and works with mach3.
    my little milling machine is a proxxon MF70 cnc which as an extended work area to allow for making the parts needed.
    now I have tried a number of CAM programs fusion 360 but what it shows on the program sim it does not do with the machine for some reason.
    I would like a CAM program that allows me to see the sim cutting the work in detail and that is easy to set up as I am a dum ass.
    whats out there that will fit the bill. michael
    Hi Michael
    Welcome to the forum.
    I don't have a machine but have been lurking in the background for a couple of years, have a look @ fusion 360, a lot of the members use this software it does CAD/CAM and if you go over to u tube there are lots of instructional videos.
    Enjoy the forum.
    Regards
    Mike
    Hi Michael,
    So if I understand correctly, this is a two stage solution required.
    1: to get some confidence that the machine is doing what your file says to do.
    2: Do virtual cuts to confirm that the code is all there.
    Can I ask do you have Mach configured? ie set the steps/distance?
    Have you selected the correct Post Processor in Fusion?
    Is it possible to have a little more info on " it shows on the program sim it does not do with the machine for some reason"
    My first cut on any machine is a straight line. Check that the slot width is what the cutter dimensions are.
    Next cut is a 3-4-5 triangle. This is a tell all test.
    A comment on the proxon .. double check your cutter speeds and feeds! and COOLANT! .
    Regards
    Paul
  1. RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
    By Felix.U in forum Projects, Jobs & Requests
    Last Post: 01-12-2015, 02:00 PM
  2. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  3. Ridges in 3D profiles = hair loss and lots sandpaper
    By Shinobiwan in forum Machine Discussion
    Last Post: 11-04-2013, 07:45 PM
  4. NEW MEMBER: lots of questions
    By jsa2001 in forum New Member Introductions
    Last Post: 01-10-2009, 09:09 AM
