Thread: Emco PC120 Turn
10-08-2017 #131
10-08-2017 #132
Ill also check the current setting - may bump this up (if not max already) and see if its makes the response better.
10-08-2017 #133
Have you tried running the lathe with a voltmeter (an oscilloscope would be better) on the powersupply to see how it's handling the load?
If you were getting good enough performance with 24V, I probably wouldn't be inclined to bump it up that much. I'd probably aim around 30-40V, but it would really depend on what the motors could handle. Remember higher voltage just means better performance at speed. At low speed it won't make much, if any difference.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
10-08-2017 #134
12-08-2017 #135
Interesting, no vault drop. The drives are actually 3M860.
I tried to set the current up - no change. Ive then ensure all the bits are well lubricated (the pump hasnt been run for a while), no real improvement.
Set the max speed down, seems OK at 700 although it should be able to do 2000 I think from the spec / manual.
Perhaps the lubrication is not getting to the dovetail / sliding area, difficult to get there without removing a lot of stuff. That said, it should be adjustable, will do some further research, perhaps the motors are stalling due to this.
12-08-2017 #136
I wonder if there's something else damaged. It's a bit suspicious that everything worked before on 24V, yet now it doesn't.
Without an oscilloscope, or swapping parts, it's all pretty much guesswork. The fact the relay board got damaged before, possibly suggests the BOB might also of been damaged, and is something that only shows up at higher step rates.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
12-08-2017 #137
Perhaps however Ive since swapped it.
Im tempted to put in another PSU but not worth spending on. I seem recall that I was pretty much on max before. The motors look fairly old, I cant find a spec for them, perhaps something else that wasnt done correctly doing the retrofit.
12-08-2017 #138
So, Berger Stepper motor.
4.4A, is that 50V DC?
12-08-2017 #139
Found this - http://www.equitecnica.com.ar/files/...225212_8_9.pdf they only list 1 motor that does 4.4A, the torque matches. Max Supply Voltage is 92V according to this .... wonder if its correct. Might explain why the motor doesnt perform running 24 Volts.
13-08-2017 #140
Noted that the drive can do a much better microstep rate. I wonder if the motor would support that and give me any better performance?
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
