Thread: Emco PC120 Turn
20-11-2016 #51
Thanks. The problem is to tighten into the slot you need to get behind the tool. Ive done some CAD drawings of the setup. Just rendering them quick, not sure if it will show the issue.
I made a bracket but out of alu which bent. Might try one from steel instead. The issue is the Glanze tool I have has a max of 25mm, so not ideal. The blade type would be better.
20-11-2016 #52
Ive drawn the blade holder in glass to see through it. It can be shortened, as it will hit the rear of the turret (centre).
The issue is how to tighten the 'spacers' that are use to squeeze the 12mm tight against the turret (vertically)?
20-11-2016 #53
The question is how to get to the nuts to tighten up.
I could drill the holes at 30 degree and use the drill bit holder 'holes'. A bit risky and need a sine vice for that. Alternately perhaps cut slots to allow me to get to the size 8 spanner to tighten up.
20-11-2016 #54
20-11-2016 #55
What diameter would you like to part?
20-11-2016 #56
20-11-2016 #57
GTN style insert up to 32mm diameter - https://www.shop-apt.co.uk/part-off-...2mm-shank.html
WDN style insert up to 26mm diameter - https://www.shop-apt.co.uk/external-...max-depth.html
(APT do do a 32mm version, but they're showing as out of stock)
I personally use the WDN style, as I couldn't find a reasonably priced 12x12 shank holder for GTN types when I was originally buying holders.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
21-11-2016 #58
21-11-2016 #59
If I remember, I'll get some rough measurements for you when I'm in the workshop later, as I've got a couple different ones.
21-11-2016 #60
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
