Thread: Emco PC120 Turn
The smaller diameter range non-reversible jaw set on self centring chucks still have steps on the outside for gripping the inside of cylindrical work, it's more common on smaller chucks that just one reversible set is supplied.
A quick and easy way to check is that the teeth which engage the scroll will have symmetrical inner and outer faces if the jaws are reversible,
02-08-2016 #2
Thanks. I dont think this one is reversible. Pity, I need around 100mm and only have 85 or so.
ATC works. Got an idea how to do offsets but not sure how you 'centre' a drill.
The spindle is being given controls via RS485. It doesnt work on power up. Enable the plugin for the VFD, it works but trips (kicks out reset on software). Then disable the VFD plugin, it works without a problem. That said, it spins the wrong way initially then the correct way. The speed inputs also dont seem to work well. Might need to reset this setup and start again.
Any thoughts?
02-08-2016 #3
DTI, jog buttons, then use the tool setup page to set the measured X dimension to zero and update the tool offsets.
Any thoughts?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-08-2016 #4
Thanks. Not sure I understand about how to centre the drill but I need to play around more. I understand offsets and how tools will vary. If you have a set size in the chuck (lets say 20mm rod), then you use the edge as the reference. Suppose I could do the drill the same way.
I understand too that Z is set when you face a part, so this is fairly easy. What I'm not sure about yet is when / how do you set your X to Zero (assuming master tool is in the turret)?
Also, there is wiring coming from what I believe to be a spindle pulse generator. Then another set of wires going elsewhere with a part missing in between. I assume this could be some form of 'interface'. Without accurate spindle counts I cannot thread, is this correct? Any other major drawbacks?
03-08-2016 #5
You have to use a dial gauge to get the drill on centre in the X-axis movement. Stick the dial gauge to the chuck, then spin the chuck/dial gauge around the shank of the drill/holder, and jog the X axis until the drill is on centre. If the drill is at the wrong height, then there's an alignment issue with the turret.
If you have accurate homing, then you don't need a master tool. All the offsets are simply taken from the home position.
The master tool process is only needed if you're homing the machine manually, so you can take a test cut with the master tool, then enter that value to manually set the machine position, then have all subsequent tool offsets set from the master tool.
Also, there is wiring coming from what I believe to be a spindle pulse generator. Then another set of wires going elsewhere with a part missing in between. I assume this could be some form of 'interface'. Without accurate spindle counts I cannot thread, is this correct? Any other major drawbacks?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-08-2016 #6
Thanks. I tried to put on a dial gauge last night but space is an issue. I need a smaller setup.
In terms of home position, I am hoping that with electrical proximity switches, this will be fairly accurate. I will do some tests later.
On the sensor for the spindle, I noted what I recall to be 3 wires coming out from the sensor. Let's assume this is a single pulse (or needs to be converted somehow), is there normally an input into the BOB or similar to read these? If the sensor is damaged, is there a part that can be bought that will give me what I need (like a generic generator that works with most setups)?
Many thanks for your help / info, been very useful.
02-08-2016 #7
Also, The tool max length I can use is around 68mm long. Any longer and it catches on the Z axis coverplate. The manual indicates that 12mm tools are max size and on centre. Thing is, they are all too long. Is it common to cut them shorter? Even boring bars are typically too long and as they cannot protrude out the back, need to be shortened?
I also need to work out the CW and CCW. For normal turning, the lathe spins 'backwards' as the turret feeds from the top but for drilling you need to spin different direction. How / where would you set this?Last edited by Chaz; 02-08-2016 at 08:30 PM.
02-08-2016 #8
02-08-2016 #9Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-08-2016 #10
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
