  1. Quote Originally Posted by Boyan Silyavski View Post
    Forgive me my ignorance, but how is that better than my 10 euro multimeter from lidl pdm 250 a2?
    You obviously don't understand multimeter snobbery, if you pull anything less than a well used Fluke 17B out of your bag you cannot hope to be taken seriously. I laugh at your Lidl multimeter, "ha!"
    Or the good old Avo 7
  3. Quote Originally Posted by Clive S View Post
    Practically on the same spiritual plane as the orca. I envy your Avo 7, but only if you have the case
    - In burnished leather.
  5. #15
    Of course, but I got rid and bought an Avo 8 mark 3 and that makes a very good door stop
  6. #16
    That's the multi in multimeter. Another advantage is that you are more likely to notice if one of those thieving sparkies tries to make off with it !
    Don't be daft they wouldn't be seen dead with anything less than a fluke, when/if they can find it amongst all that mess they call a work van :D
    AvE of youtube did an interesting video recently:
    https://youtu.be/XDm5BfRrAsg
    Then a follow up:
    https://youtu.be/rJm9iCha-jM
    .Me
    .Me
  7. #17
    Then a follow up:
    .Me
    this is a great video channel, quite refreshing disassemblies of stuff
    how you can trust your measurements with meter like that.
    I compared all my flukes with those cheap crap and they were miles away - mostly in A mode, even voltage was off.
ID:	19022Click image for larger version.
    Forgive me my ignorance, but how is that better than my 10 euro multimeter from lidl pdm 250 a2? I see the bench one could measure temperature, but i have very good laser gun thermometer to 1300C . Anything else that one might need ? In the DIY CNC line of things i mean.
    Attachment 19004
  9. #19
    Quote Originally Posted by Tom J View Post
    The accuracy of the UT-801 for my purposes is adequate. The €10 meters are OK for checking continuity. Voltage, resistance and current within 5% is OK if you know the limitations.
    My UT-801 will sit on a bench, it doesn't have to be rugged. I am not in the habit of flinging the meter across the shop in frustration, therefore it doesn't need to be a Fluke.
    The main difference between the UT-801 and a Fluke 87V is £300, which is the most significant one for me.
    Cheers,
    Rob
  10. The Following User Says Thank You to cropwell For This Useful Post:
  11. #20
    Rob you are forgetting that the Fluke lets out scented magic smoke.
  12. The Following User Says Thank You to Clive S For This Useful Post:
  1. CNC pneumatic bench clamp
    By joss01 in forum General Discussion
    Last Post: 17-11-2018, 05:47 PM
  2. Bench-top or welded frame
    By Doddy in forum Gantry/Router Machines & Building
    Last Post: 05-03-2018, 07:45 PM
  3. Welding bench
    By Boyan Silyavski in forum Metalwork Project Showcase
    Last Post: 12-07-2015, 05:01 PM
  4. WANTED: Boxford 160 tcl bench top cnc lathe
    By sbdtasos in forum Items Wanted
    Last Post: 09-07-2015, 07:48 AM
  5. Bench Top Mill
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 04-06-2010, 06:57 AM
