Page 2 of 2 FirstFirst 12
    So how is the performance with the original lead screws Clive? can you zero out the backlash in the cross slide?
    Thanks A_Camera, yeah I think I will invest in the cable and brake, they are out of stock now so will have to see how long it takes them to restock before I make my final decision. Having looked at the PID in more detail I think you a right and it is more suited to the slower response of temperature control rather than machine spindle control. How does the jog control work? is it like a servo motor for indexing?
    Thanks M_C. the motor I was planning to use is an inverter duty 4 pole so should be good from 150 to 3000rpm. 2.2kw specs are:
    For Variable Speed use:-
    Part Time Output when Inverter powered is...
    7.30Nm - 2.2kW ( 2.95HP) x 2880 RPM at 100 Hz
    14.59Nm - 2.2kW ( 2.95HP) x 1440 RPM at 50 Hz
    14.59Nm -1.1kW ( 1.47HP) x 720 RPM at 25 Hz
    14.59Nm - 0.22kW (0.29HP) x 144 RPM at 5 Hz
    Continuous Output when Inverter powered is...
    10.4Nm -2.2kW ( 2.95HP) x 2016 RPM at 70 Hz
    14.59Nm -2.2kW ( 2.95HP) x 1440 RPM at 50 Hz
    12.40Nm - 0.94kW ( 1.25HP) x 720 RPM at 25 Hz
    7.30Nm - 0.11kW (0.15HP) x 144 RPM at 5 Hz
    The lathe is only 125mm centre so not much capacity for large stock and low rpm. I was more looking for indexing at low speed. I will check the cutter forces though.
    I don't zero out any backlash because I find that on the lathe you (or I) always back off from X at the end of the cut run and then then any backlash is taken up when you start the next cut. If that makes sense. The conversion I did was from this guy http://www.jeffree.co.uk/modelengineering.html
  1. Need help with a sensorless vector VFD and 2.2kw motor.
    By kajuk in forum Spindles & Drive Motors
    Last Post: 04-06-2015, 09:54 PM
  2. Need help with a sensorless vector VFD and 2.2kw motor.
    Last Post: 29-01-2014, 05:09 PM
  3. bitmap to vector conversion
    By GEOFFREY in forum Computer Software
    Last Post: 29-12-2012, 05:32 PM
  4. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 07:11 AM
  5. Vector graphics AKA CAD for free
    By m.marino in forum Computer Software
    Last Post: 15-01-2009, 01:17 AM
