Hi all,
Just wondering if it is necessary to use the enable pins, I notice a lot of setups do not use them. What is the purpose of them? Any drawbacks to not using them?
So it would be a good idea to use them then? It is only an one extra wire to hook up.
21-08-2016 #5
I use a Pilz safety relay which sends an e-mail stop signal to the motion controller, takes power off the driver power supply, and also removes the enable signal from the drivers. One of those should stop the machine! The safety relay is tripped by the e-stop switches and the driver fault signals which are all wired in series. There are enough relay contacts on the safety relay to do that so, as you say, for the sake of a piece of wire it's easy enough to do. I wanted to make sure that the stall detect would stop the machine as I am using slaved motors for the X axis.
21-08-2016 #6
[Posted twice]
Doesn't the EN pin free the motor so you can do a bit of manual positioning? If so it makes for a crummy emergency stop because there is no braking. OTOH if your drivers have no pattern memory and revert to a set home pattern when you switch on, then EN would be a good option if you wanted everything to cool down while you replaced a broken tool, went out to buy milk, fags etc.
24-08-2016 #8
You don't have to use them, they are automatically pulled to the enable state by internal circuitry in the drive, if you connect the appropriate external circuit for your drive to pull the enable pin to the disable state the drive is disabled.
It's down to you to decide if you need this function and what for, if you don't need to disable the drives ignore it as enabled is the default state for common drives,
- NickLast edited by magicniner; 24-08-2016 at 12:40 PM.
30-10-2019 #9
I know this is an old thread, but for folks searching for information about using the enable pin: Check the current requirements of your driver input and the current capability of your BOB/controller before you hook multiple enables to a single output on your BOB. A lot of the drivers draw 12+ MA. on their input pin and some BOB/Controllers can only source as little as 24mA.
How to wire the enable pin on a stepper drive?
By cncJim in forum General ElectronicsReplies: 8Last Post: 01-01-2016, 05:10 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
best stepper driver???????
By Ross77 in forum Motor Drivers & ControllersReplies: 37Last Post: 21-04-2013, 05:05 PM -
Boxford 125TCL Stepper Specs required.!!
By JAZZCNC in forum Boxford LathesReplies: 7Last Post: 01-02-2013, 01:28 AM
