Thread: Thread sealer.
Page 2 of 2 FirstFirst 12
    A bit late to chime in, but normally for this job i use epoxy. My vacuum station is all sealed with epoxy, so is my compressor and mist system. If i am in doubt that will have to unscrew it later, i use the 2euro epoxy from a chinese shop. Which works well. if propane or oil is involved, i use expensive epoxy.
    As a friend said once- " all you need is one hand distance aways from you, just look around, you have it"
    Also i think the double syringe item shown will mix the epoxy in the nozzle so no air entrainment ?
    Mike
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 6 Days Ago Has been a member for 6-7 years. Has a total post count of 393. Received thanks 42 times, giving thanks to others 18 times.
    That friend wasn't Eric Cantona, was it..?
    Those double syringes are cool, but mixing the resin/hardener/colour paste requires odd quantities and furthermore they need measuring out by weight, ie. 10g of resin + 0.5g + 5g hardener. Might be worth trying a syringe to dispense into the more detailed parts, although I have a feeling that the mixture will be a little too viscous... On the smaller stuff I'm currently over-pouring and then sanding back the excess before polishing which gives a nice flush finish, but I do like the way that the epoxy 'sags' into the pockets on larger designs - you get some nice reflections.
    Wal.
  1. inspiration thread
    By kingcreaky in forum General Discussion
    Last Post: 21-01-2016, 03:08 PM
  2. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  3. Thread diameter
    By Daniel in forum General Discussion
    Last Post: 23-02-2012, 06:18 PM
  4. Not Just another Boxford tcl 125 thread....
    By cooliced in forum Boxford Lathes
    Last Post: 18-08-2011, 10:15 PM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
