Page 2 of 2 FirstFirst 12
    I decided to make some changes since I discovered some Brains features which are useful in the design of Brains file. I have also decided to split the file into two parts, one is the basic control and the other is the "bonus features". I think this makes it simpler for others to reuse my idea and adjust the necessary changes.
    I have also made a short video which could be used as a simple guide. This video is just the first part. At the end of the video there are three pictures showing the brain file with the basic controls with three Mach3 commands: M3 S3000, M4 S9000 and M5.
    For best detail, please watch in full screen mode. It is 19 minutes long, so if you just want to see the Brain file views you can jump directly to the last 40 seconds.
  2. The Following User Says Thank You to A_Camera For This Useful Post:
  3. #12
    I'm very interested in this, but then, I am a techy...
    It's not because of the start/speed control aspect, as this is pretty straightforward if you have a BOB or motion controller with adequate analogue output. OK, linearity might not be absolutely spot-on but I doubt that for most practical purposes that matters.
    There is one HUGE disadvantage with using 0-10V, at least with the BoB's I have, is that if Mach3 is not fired up and the BoB is getting power then it will output 10V and random states for the digital outputs. This creates a dangerous situation since the spindle can start spinning when your hands are too near. This situation can never happen if you use Modbus.
    However, the idea of being able to read back VFD parameters (spindle speed, etc) to display on the PC screen sounds attractive. Personally, I would not have considered this because I had no idea what a Mach3 brain was so would have never gone looking for this kind of information. I've probably missed something obvious, but I don't find the Mach3 documentation leaps out at me. Easy enough to do the basics but you seem to be somewhat on your own if you go just a little off-piste.
    I agree, this is another major advantage of using Modbus, and I will cover that in my next video. I am reading parameters like Output voltage, current, torque, power, temperature, real RPM, RPM stable... and there are plenty more, but to read those and have some use for them you also need to modify Mach3 screens used, otherwise you won't be able to see those. I have just started with this, so I am no expert, but used Screen4, which can be downloaded from Mach. I find it pretty buggy, crashes fairly often, so frequent backup of the changes is really important, but it is free, so why complain? In any case, to make modifications to existing screens is pretty simple.
    For example, do a Google search for "mach3 brain" and the best result seems to be a YouTube video. Personally, I would rather have a decent manual in front of me!
    But maybe I've just missed some hidden site full of Mach3 docs, so if anyone can tell me where it is... In the meantime, I shall follow this thread with interest.
    Yes, I would also prefer a decent manual, but that is hardly going to happen now that Mach3 is dead. The Brains territory is even less documented than the rest. I managed to gather quite a bit of documentation spread around on the Internet about Mach3 macro programming, use and parameters, as well as about some other bits and pieces, but very little about Brains, so that is not really like skiing off-piste, more like skiing off-piste uphill. Yes, the best I could find was also Youtube video, but unfortunately not enough to help me, so I made my own. I don't know if I will write some kind of user documentation later on, because it takes quite a lot of time, but at least I will document my workflow which can be use by others to figure out what to do and how to solve their problems.
  4. #13
    I can't disagree, although in my case I am using a CSMIO-IP/M which is held in e-stop mode by the safety relay until it is explicitly re-enabled. I think that it stays in standby until it starts communicating with Mach3 as well - I'll have to unplug the Ethernet cable while it is running and see what happens!
    As I am currently using a Huanyang VFD and given its poor support for Modbus, I'm not going down that path. Still, if it blows up one day and I have to replace it, then I might well look for something that both supports the official Modbus standard and also has a usable manual!
    Good luck with this project - I shall follow it with interest.
  5. #14
    A-Camera, thanks a mil! I had been beating my head against a brick wall for weeks trying to get this going. Using your posts I got it all up and running sweetly
    I registered on this board just to thank you!
  6. The Following User Says Thank You to Thermic For This Useful Post:
  7. #15
    Quote Originally Posted by Thermic View Post
    Thank you for your kind words. I am glad it helped you out and hope you'll enjoy using Modbus just as much as I enjoy it. I no longer use Mach3, using UCCNC now, but I continue using Modbus even with UCCNC.
  1. Supercomputer models one second of human brain activity
    By Lee Roberts in forum General Computing
    Last Post: 20-01-2014, 04:31 PM
  2. Mach3 digitizing wizard not saving file
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 08-09-2013, 08:48 PM
  3. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 01:37 PM
  4. HID interface for remote control of Mach3
    By Smiler in forum Electronic Project Building
    Last Post: 10-05-2009, 11:59 AM
