12-09-2016 #1
Hello
Thank you for reading
I was taught that minimizing run-out is essential for successful drilling
I can see machinists making dowel holes with HSS drills in collets, and sometimes these drills run even more than 0.1mm out, on steel and aluminium.
I know the spot drill defines the position of the holes, however drilling with a drill which runs more than 0.1 out, I would not use it even to make a normal tapped hole for a high precision job
What’s your experience about run out
Thank you in advance for your support
08-03-2017 #2
Relative to the job - 0.1mm is fine for a hole that is to be tapped, for dowel holes, they must be reamed to fit.
Drills are only ever treated as a way to get an approximate sized hole, the accuracy is added later by machining or reaming or boring etc.
If the spot-drill is used correctly then the drill can be quite bad and still drill in the correct place.
08-03-2017 #3
Collets come in different tolerances. If your vender does not mention tolerance you can probably assume they are from the cheap end of the pile
Dowel holes reamer or interpolation?
By hoezap in forum Metalwork DiscussionReplies: 4Last Post: 10-04-2016, 12:44 AM -
dowel pins & corresponding drill sizes to get a tight fit....
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 7Last Post: 04-07-2013, 08:50 PM -
correcting mill spindle runout
By cocoa_cnc in forum Spindles & Drive MotorsReplies: 4Last Post: 18-01-2009, 06:43 PM -
Measuring Spindle Runout
By Lee Roberts in forum Spindles & Drive MotorsReplies: 0Last Post: 18-10-2008, 11:47 PM -
Dowel Pin Drill jig
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:34 AM
