    Hello
    Thanks for entering my post
    What sort of system do you use to get the best flatness on hard material like heat treated steel.
    We are supposing to machine a normal plate rectangular or square shape of any dimension, clamped firmly on the bed.
    I can see some machinists using normal face-milling with tips, and some of them use the technique “always the same direction” which is the most traditional method.
    Some others use the technique starting from outside and going around, climb milling, and finish in the middle and rolling on the corners.
    The latter seems very efficient on hard material.
    Some others use the system with wiper inserts.
    What sort of method you use and what sort of tolerance are you able to get with you method?
    Are you able to get flatness with a tolerance less than 0.015mm
    Thank you for your support
  2. For heat treated steel, grindng on a surface grinder would be used.
    Quote Originally Posted by hoezap View Post
    Hello
  1. Bed "Flatness"
    By Nthkentman in forum Machine Discussion
    Last Post: 06-10-2014, 10:28 PM
