    Hi There,
    I am posting to find someone in London area who would be able to quote and produce machined aluminium plates for me.
    First of all would like to apologize for the quality of the drawings in AutoCad as I am nowhere close to even beginner level when it comes to this software, but non the less the drawings are 1:1 dimension of what I require and can be measured if there is dimension bit missing.
    Click for link to DropBox (PM me if your require alternative way to acquire these drawings)
    Support Block Plate
    Dimensions: L 200mm x W 45mm x H 15mm
    Number of plates needed: 2
    Special requirements: Holes along the plate's side, require to be threaded for M6 diameter screw.
    Nema23 Mount Plate
    Dimensions: L 190mm x W 90mm x H 10mm
    Special requirements: 4 holes for stepper mount require to be threaded for M5 diameter screw.
    Vertical Mount Plate
    Dimensions: L 200mm x W 185mm x H 10mm (triangular plate)
    Number of plates needed: 4
    As for the material, I already have acquired Aluminium Cast Tooling Plate (AW5083) I have them in various dimensions suitable for each part and would be able to bring or send them over.
    Looking forward to hear back from your guys :)
    All best,
    Aigars.
    Hi again,
    Have updated files with bit more description, view's and separate dimensions sheet.
    Hope it help to get the idea of what is required to be machined.
    All best,
    Aigars.
    Thanks all for your interest, have got already someone who will make me these pats.
  1. Machining airspace parts please heeelp!!!!!
    By hoezap in forum Metalwork Discussion
    Last Post: 03-09-2016, 12:19 PM
  2. RFQ: RFQ: Very Simple Machining of Two Aluminium Parts Required
    By biketrialsdave in forum Projects, Jobs & Requests
    Last Post: 15-12-2015, 12:01 AM
  3. scm tech 95l cnc machining centre User manual or parts lists
    By george uk in forum SCM Group Routers
    Last Post: 28-04-2015, 08:18 AM
  4. RFQ: small machining job??
    By Wobblybootie in forum Projects, Jobs & Requests
    Last Post: 25-02-2011, 01:04 PM
