12-09-2016 #1
Hello
My build has been going slower than i thought and to build my current round rail design and upgrade will take a lifetime so i have Emailed Fred at BST Automation. I thought it would be easiest if I got everything at once to make the freight cost better. but i'm not really sure if i have got everything correct on my parts e.g the correct voltage for the motors and drivers. i haven't asked him for power supplies because i Forgot.
Would you say its better to do it this way or buy the parts as and when. It would make my simple brain think the build was a better price to fool me and make the nearly truths more believable to my wife.
Here it is my great pleasure to quota the price for you,for
Hiwin 20 mm Rails & Blocks
2pcs hgr20 - 1200mm Rails
2pcs hgr20 – 1000 mm Rails
2pcs hgr20 – 300mm Rails
12pcs HGH20CA Carriage
1set RM1605-L1000mm ball screw with ballnut
In standard end machined and 1000mm is the overall length.
1set BK12/BF12 End support
1pcs 1605 ballnut bracket
4pcs 8x10 Flexible coupling
X1 Water Cooling Spindle Kit 2.2KW CNC Milling Spindle Motor + 2.2KW VFD + 80mm clamp + water pump / water pipe for CNC Router
X4 Nema23 3A 425oz-in Motors
X4 Motor Controllers
Best price is USD1300.00,included the freight by Fedex.
Some details,
1)The Linear rail and carraige are in original HIWIN brand.
2)We will machining the ball screw end in standard,and 1000mm will be the overall length,included the machined part.
3)The BK12/BF12 we quota to you are in cheaper type with Deep groove ball bearing,if you prefer higher accuracy and the BK12 in Angular contact bearing,we can offer to you,and the cost will increase USD18.00.
4)Not fully understand what's your meanning of "X3 1605 Couplers",maybe you mean need some extra coupling?and I quota to you for 4pcs 8x10mm coupling to you,8mm are for the stepper motor shaft,and 10mm are the machined ball screw end.
5)The NEMA23 motor we quota to you are in 8mm shaft diameter,3A and 425oz-in.
Delivery can be arranged in 5-7 working days.
Anything can do for you,please contact,thanks.
Thanks for your reply.
The motor driver is DM542 model,
For 2.2kw spindle motor,will send 4pcs bearing version to you.and the main spec. is,
1) Dimension: 80*240 mm
2) Power: 2.2KW
3) Voltage: 220V
4) Frequency: 400 Hz
5) Speed: 0-24000 R/min
6) Water Cooled
7) ER20 collets chuck
8) Runout off: less than 0.02mm
Best wishes
Fred
I would be very grateful if you could look to see if i'm on the right road, Last time I went ahead with the sbr20 without asking ans regretted it. the machine isnt really designed for any particular use and so an all rounder is hoped for and hopefully make a little back in time on small jobs
RobLast edited by grain_r; 12-09-2016 at 09:58 PM.
12-09-2016 #2
Rob it's hard to answer questions without the machine details why don't you keep all the questions in one build thread and then others and me can follow along.
Do you already have some parts or is this supposed to be the complete setup for the machine.
In item 3 above he say he has priced for deep groove bearings the Angular contact bearings are much better. I also would be buying the motors from cnc4you as you will know what you age getting and they are tried and tested...Clive
13-09-2016 #3
Good Morning Clive
Thank you for the reply.
My Build Log is here http://www.mycncuk.com/threads/7936-...3396#post83396
although not so much building has happened just lately after the arrival of our new baby girl although I occasionally get to the garage for a few minutes.
Being a silly billy I originally bought the SBR20 rails and ballscrews 1605's from Aliexpress and then researched after which I now realise wasnt the way but a good learning curve I have nearly got my frame and because of the time taken I don't want to come out with a second rate machine.
The parts I have are 1000mm SBR20, 500SBR20,& 300MM SBR20 Rails and the ballscrews to go with them I though I would sell the rails but keep the screws and then come out with a better machine its all that deans fault
I will have a look through cnc4you
I need to go through the logs of the machines for the electronics because I havn't really been working on that part but it's difficult to know where to start And I don't want to get it wrong this time.
thank you
Rob
13-09-2016 #4
Ok Rob either keep using your build log or start a new one and keep it all in one place. Have you any drawing done for the nee machine? I would not buy any electronics until you have the basic design done. The drives I would use would be AM882 or similar ( they will handle 80V and are known to be good and tested.)
Are you going to design it with belts and pulleys . If you are using two motors on X have you considered one motor with a belt between the two. Like Dean does.Last edited by Clive S; 13-09-2016 at 10:31 PM.
13-09-2016 #5
Good Afternoon Clive
Thanks for the reply. Yes I will keep it ijn my Build log I was going too but I thought I should put it in the right forum section but I prefer to keep it all in the same place.
No I haven't altered the drawings although I know what I want to achieve in my mind. It will essentially be the same design as it was going to be with the SBR Round rails and I did design it for rails to be upgraded later in mind but I couldn't stand the thought of having drilled the holes and then swapping and it just looking so messy.
I did think originally for opting for the 1 motor and pulleys but I just couldn't get the design right because I want to be able to end mill and so I wanted to keep the ends free to clamp too although I have through after I will be able to take the spoil board off and clamp to the frame center section.
It does seem like I'm not on the best path to get everything from Fred So maybe It will be best to get the rails and the Ball-screw and then when i'm further down the road to research individual items.
I will certainly look at the AM882 driver so thank you very much for giving me a starting point to look at.
I still have a long way to go I feel before the Spindle goes in. My excitement gets ahead of me. Are the Am882 best to go for somewhere like cnc4you or are the Chinese versions the same ?
I probably should be looking at the epoxy level before the other items.
thank you
13-09-2016 #6
Ok then post some current pics up the the build log and start from there.
13-09-2016 #7
One not so obvious consideration is the ballscrews getting bent in shipping. I'm not sure if this is an issue with BST, but ordering everything in one go can help as it makes the package stronger.
14-09-2016 #8
One thing I'd definitely would change in that order is the flexible couplings. Those are not suitable in my opinion. Get the lovejoy type, much better. It demands better alignment but offer also better accuracy, less vibration and better speed response. Not a very high cost and easily can be changed to at a later stage if you want to try what's included in your order, but considering the overall costs, I think it is better to do it now, and not waiting.
14-09-2016 #9
Hi
I would not use direct coupling Motor/Ballscrew use belt and pully, Dean always recommends this setup to reduce resonance.
Regards
Mike
14-09-2016 #10
FOR SALE: SBR 20 supported round rails and bearing blocks
By JoeHarris in forum Items For SaleReplies: 10Last Post: 09-02-2015, 02:06 PM -
WANTED: 2 x 20mm Fully Supported Round Rail
By longy in forum Items WantedReplies: 0Last Post: 30-03-2014, 09:21 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM
