    Hi all
    i need to get a pump for a 2.2kw spindle, can anyone recommend a good unit, the 'bay is a minefield of small pumps most of which would likely be crap ;)
    If your coolant is distilled water with a little something to stop it turning funky you could use a pond pump, decent ones are reasonably priced and they will run constantly for years, your setup could then be based around a 4 gallon header tank with a submersible pump with the option to add cooling on the return side,
    - Nick
    I used a 50/50 mix of water and anti-freeze on the mini-mill.
    The label has disappeared so i have no idea what flow rate to look for, head needs to be 2m max but is small bore tubing - 8mm i think
    I think the min pump had to be 400l per hour. There is quite some loss from that due to height , long lines, lines width, ... In reality the actual flow needed to cool a spindle is minimalistic
  5. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  6. #5
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,553. Received thanks 167 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    .Me
  7. The Following 2 Users Say Thank You to Lee Roberts For This Useful Post:
  1. Water cooled / air cooled 2.2kw spindle
    By suesi34e in forum Generic Chinese Spindles
    Last Post: 25-02-2015, 03:57 PM
  2. Do you need to water cool erhm a water cooled spindle?!!
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 02-10-2013, 08:59 PM
  3. Replies: 17
    Last Post: 18-09-2013, 05:32 AM
  4. Spindle Water Pump
    By Tomnewry in forum Spindles & Drive Motors
    Last Post: 11-08-2013, 12:05 PM
  5. Just how quiet really are the water cooled spindles?
    Last Post: 30-11-2011, 10:27 AM
