25-10-2017 #221
25-10-2017 #222
Yes i figured it out. You have to wire it as the manual, however the VFD is slightly strange as you have to ground both the ACM & DCM (Analogue & Digital Grounds) to each other. A bizarre occurrence to me, not sure what the Chinese logic is behind it but it works. I can now control the M3/M5 commands and set the speed from the DDCSV1.1.
Alex
16-11-2017 #223
16-11-2017 #224
Sadly YouTube's closed caption translation feature reads like a Chinese written manual and I don't speak the language used :-(
A written review to accompany the video might reach a wider audience?
16-11-2017 #225
I like you fitted the controller it looks great. I seem to have an issue with mine now where; if i leave it powered down for long than 5 minutes or so, when i boot it back up, it doesnt boot first time, instead i get a long beep and the backlight of the display, if i switch it off and back on again it works perfectly, very strange.
Alex
10-12-2017 #226
In DDCSV2.1 change PNP inputs to NPN!
24-12-2017 #227
24-12-2017 #228
24-12-2017 #229
26-12-2017 #230
I use CAMBAM. It lets me change between inches and mm.
I already have many files created in inches. Changing them to mm instead of inches seems to make no difference.
When I try to run one in inches it seems to run in mm instead of inches.
My spindle is calibrated to move 25.4mm to get 1in of travel, so assume if I increased my numbers 25.4 times I would get what I want. Except I don't want to go through my files and convert them manually.
Am I missing something to get files to run at a 1 on the display = 1in ???
Thanks for your responses so far guys!
CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
By dudz in forum CS-Lab (CSMIO)Replies: 35Last Post: 02-01-2017, 01:27 AM -
FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
By lateAtNight in forum Items For SaleReplies: 1Last Post: 24-06-2014, 03:41 PM -
FOR SALE: Galil 1880 8 axis PCI motion controller
By Boyan Silyavski in forum Items For SaleReplies: 1Last Post: 03-06-2014, 07:39 PM -
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
eBay: Galil DMC-1580 Motion Controller 8-Axis
By Boyan Silyavski in forum Items On eBay UKReplies: 1Last Post: 25-12-2013, 10:30 AM
