    i saw this machine on ebay,,,,and was wondering if anyone has used ,or seen a similar machine in action..any thoughts or advice would be appreciated...
    http://www.ebay.co.uk/itm/UPGRADED-1...l6368#shpCntId
    Old post but you may still be asking!
    I've got the 60 watt version which seems essentially the same but without the 'under cupboard' When it arrived the crate had been broken and there was some cosmetic damage and a few wires off their correct locations - hinges loose - that sort of thing. Negotiated a discount and fettled it. One thing I thought was appalling was an override switch on the front panel that overcame the 'cover shut' safety switch, so that was removed. I also replaced the rather nasty sockets provided on the back for decent quality IEC ones (these are for the chiller, air pump etc)
    It works quite well and does what I want, but the documentation (as always with Chinese stuff) is rather hard to follow. It's not obvious whether the power and speed settings on the machine panel over ride the software settings in RD Works (the driver package provided) for instance.
    John S's Avatar
    Lives in Nottingham, England, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,061. Received thanks 140 times, giving thanks to others 45 times. Referred 1 members to the community.
    No they don't Andrew, the panel setting that is.
    Last night i had mine set to 2 for speed as i wanted to jog it to a certain position but when i ran the program it cut at the specified 40mm . sec or whatever, certainly not as slow as 2.
    John S -
  1. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  2. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  3. Advice on running YAG laser in UK
    By chriggy in forum Laser Machines & Building
    Last Post: 09-02-2015, 02:29 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. new laser
    By mike techserv in forum Milling Machines, Builds & Conversions
    Last Post: 06-06-2009, 02:17 PM
