    Good Evening All,
    Firstly and a bit presumptuously thank you all in advance for the help and support that I am going to need during this build, seldom do I say that I feel part of this community before I even begin the help I have had to date has been amazing and I again would like to thank you all
    So like any successful project it needs a catchy name so given that this is what I am going to be in for the next X months or Years I decided to call my CNC Machine "Deep Thought".
    I have started to put pen to virtual paper bit rusty on my CAD skills but it is coming back - slowly. I now have the early look / feel of a machine sub frame, interestingly this has already thrown out a huge number of questions some answered by looking at other build logs other not. It is funny to think that I started in Sketchup going "This will be a few hours and I will be done" two days later I am like " hmmm - (goes of to look at MyCNC Forum) but all very very enjoyable.
    The DESIGN BRIEF
    Use case statements - bit of my job coming through!!
    “ As a user I want the ability to use my CNC machine to cut Wood (hard and soft) , Aluminium, Plexiglas and Wax blocks. I need to be able to construct the machine myself (or buy parts I cannot tool). The design should enable me to prototype in wood first to provide confidence in my measurements. It’s size needs to fit in with my workshops space without reducing the overall usable area too much. I need the machine to be able to replicate the same cuts with as little deviation as possible to keep accuracy of the end product, I would like to spend no more than £1000 on the build if possible”
    I would guestimate that the overall material usage would be 50% wood 50% other materials listed.
    The CNC bed size is 630 x 1000 mm (appreciate cutting size will not be the same)
    The key element to my machine (not unique at all I would have thought) is its ability to consistently and accurately (within reason of a self-build machine) reproduce parts that I require for my small business that will in turn lower some product overheads.
    I think that about covers it, but if you cleaver people need more to provide support and guidance please let me know what other information would be useful.
    DESIGN Trouble
    So going to try and articulate this in the correct language to try and make the question easier to answer. First some wide angle pictures of the design so far:
Name:	back profile.JPG
ID:	19286 Click image for larger version.
Name:	side profile.JPG
    Question 1 - I am a bit confused with regards to this design section, i intend to use two Y axis motors to provide much greater stability and to reduce the "racking" i think it is called or the gantry pulling or twisting that could be encountered on a single centered ball screw. Accepting that having two stepper motors increases the cost and increases the complexity of the build slightly, as well as needing to calibrate them occasionally as i understand it two is overall more beneficial that one (part A question is my thinking correct here?).
    Part two is in two parts A) how should i be connecting the ball screws to the lower cross beam on the gantry, should they be on top to provide extra support / stability ( a bit worried that it might "strike the plate" or should it be attached to the bottom as per the picture below.
    Part B) i am just not clear at all as to how i am meant to design this area, mainly as i'm not sure how the ball screw assembly is meant to be put together, so am unsure of diameter of cutouts needed for bearings, and how the ball screw would be fastened / driven by the stepper motor. I would be grateful if this could be explained- looking at other build logs it is hard to visualize as while i can see the basic principle the pics are taken far way so not able to see the layout / connectivity. Am i also right to put both ball screws as close to the gantry guide rails as possible as per picture below:
Name:	glide rails 20mm.JPG
    EDIT - looking back at the picture above i need to redesign this to protect the rail from debris from the bed!
    So this is where i am up to for now until i can address these questions, cant go any further in the tooling plate design etc as this is all centered around how ball screws work.
    Would love your feedback to see if i am designing something viable or something that is destined to the scrapheap :) will not be offended in anyway, if you think i need to overhaul the design so far just let me know why so i can correct it in version 2!
    Look forward to your opinions / answers
    Kind Regards
    Sherpa
  1. "Hacking" and "Modding"
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  4. "Racks" VS "ball screw"
  5. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
