Thread: Advice on converting my VMC
07-10-2016 #51
You might not have any experience with Adc/Daq measurement technique, but i suspect you have a solid experience in a number of other things ;-)
Yes, i'm quite satisfied with my choice. But is was baser on a lot of help from you guys :-)
07-10-2016 #52
Wait, i just checked the price of said PLC is just 125$. And has additional IO boards for 45$. Even a motion controller 250 khz for 100$ more. So it seems for less than 300$ one could combine the cheapest Chinese controller i was testing with that PLC and retrofit a mill with ATC! That is great to know.
By the way i found the way to stop and tool change in that controller
07-10-2016 #53
Go for it then Boyan 😉
07-10-2016 #54
07-10-2016 #55
What PLC are you looking at Boyan?
Sometimes you have to use a PLC, and other times it just makes life a bit easier.
Mach 3 only has a 10Hz refresh rate for Macros, which means any sort of ATC with critical timing can't be done directly. I used a PLC for the turret on my lathe, as the locking mechanism timing needs less than 50ms between sensing an input change and an output being activated, which wouldn't be possible with a Mach 3 macro.
Mach 4 does have a faster refresh rate, but I'm not sure how fast it can react.
However most ATCs on a Mill aren't that time critical. It's a just a relatively simple process cycle, with the biggest problem likely to be how long it takes. It's just a case of working out the required sequence of sensors and outputs.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
07-10-2016 #56
07-10-2016 #57
07-10-2016 #58
Humour. Guinea Pig = slang for tester.
The one he mentioned above in the thread
Other option is their range of Click PLCs, which are cheaper, but are a bit more limited in terms of supply voltages, but the programming software is completely free (I see the DL05 software is limited to 100 words).Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM
