Page 6 of 9 FirstFirst ... 45678 ... LastLast
  1. #51
    Better late than never but guitars are something I'm very interested in so I will start to follow this thread once I've caught up on the reading.
    P.S Where are the project files ? will they open in Rhino ?
    Edit: I think I'm correct in saying that the project files are accessed through Fusion360, in which case I won't be getting to them.
  2. #52
    Welcome back Eddy long time no see
  4. #53
    When you sanded the fretboard black dots it looks like there was no contamination of the maple grain. I once used ebony dots and upon sanding, it went right into the lighter wood's grain.
    I liked the idea of using a lathe to drill the truss rod hole in the heel, I guess the neck was horizontal because you were using a 2 way truss rod rather than a bowed threaded rod.
    Here's a pickup ring I made recently for a humbucker, toolpaths made in CamBam
  5. #54
    Hi Eddy - yes they are in Fusion 360 - the f3d files are also linked in my drop box on the CAM/cut out video,
    Any particular reason for not using Fusion?
  6. #55
    Yes it was a double action rod and horizontal - hence all the "hiding" I had to do to make it look like the original single action bow type with cross head adjuster.
    The maple grain was fine after sanding, normally I would clean the fret board before spraying, but this particular guitar is supposed to look like a 62 vintage, so I'm currently testing ways on offcuts of "dirtying" the wood up that also allows nitro lacquer to still adhere (which will then sadly be "worn" back again somewhat to replicate wear).
    Nice pickup ring BTW.
  7. #56
    Yes, I use Rhino3D and CamBam
  8. #57
    Been on a bit of a break from the guitar project, but lacquer has finally started to be laid down (not without some trouble of my own making):
  9. #58
    Nice burst!
  10. #59
    Nice burst!
    Thanks - it still needs some amber/clear over, which will "age" the look slightly before polishing, but I'm happy with how it came out compared to the original - better start practicing my add9th's again :-)
  11. #60
    Practice is good! Lol.
  1. FOR SALE: CNC project
    By amxen in forum Items For Sale
    Last Post: 20-12-2015, 09:19 PM
  2. NEW MEMBER: Hello My CNC UK community
    By Xavi in forum New Member Introductions
    Last Post: 30-11-2015, 09:01 PM
  3. Community Shed
    By Musht in forum General Discussion
    Last Post: 06-10-2013, 12:15 PM
  4. Central South Community
    By Leadhead in forum General Discussion
    Last Post: 26-09-2011, 02:50 AM
