Thread: Large cnc routing cutter needed
04-10-2016 #1
Hi this might sound a bit odd but im struggling to find a cutter that suites my job.
I ideally need a 30-40mm dia with 5mm radius on tip something like a spoil board cutter but with radius.
Does anyone have a clue where i could get one or I may have to hunt down a company that make spindle moulder cutter as get a custom one. This is for use on wood and i need fast area clearing with a 5mm rad.
Peter
04-10-2016 #2
Buy a couple of this one 1/2" shaft and 2" diameter. Its dirt cheap for what it is. You could easily modify the corners yourself. Or let somebody grind it for you. basically you have to round them, take same amount from the back support.
And sharpening and resharpening could not be easier on this bit using 600 and 1000 grit diamond plate.
There are cheap plates, a bit more expensive plates and there are better expensive plates. Which both work. Here is the how to video
Anyway, the keyword is "bottom cleaning bit" . That's how the Chinese call them.
05-10-2016 #3
thanks they look perfect just a pity they will take so long to arrive. Ill buy a few.
05-10-2016 #4
there are in UK http://www.ebay.co.uk/itm/BOTTOM-CLE...0AAOSwQPlV9vZl
05-10-2016 #5
Wealden have a cutter with a round edge - they don't state what the radius is - ring them up
http://www.wealdentool.com/acatalog/..._Wing_250.html
Peter
05-10-2016 #6
This any use ? http://www.ebay.co.uk/itm/Trend-Radi...item3f5b014dda
05-10-2016 #7
RFQ: LARGE CNC job - need help
By ChristoT in forum Projects, Jobs & RequestsReplies: 0Last Post: 18-10-2014, 01:48 AM -
Transporting a large CNC
By gavztheouch in forum General DiscussionReplies: 9Last Post: 02-11-2013, 05:09 PM -
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
PCB Isolation Routing
By CHudson in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 10-10-2010, 08:34 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
